FS: Turbo XS Type H BOV Brand NEW still in box!
Designed for high performance and maximum noise, the TurboXS Blow Off Valve - Type H-RFL relieves compressor pressure surge caused by changing gears or backing off the throttle quickly. The BOV Type H-RFL is designed for turbo charged engines running 10 to 25 psi boost.
The Blow Off Valve - Type H Kit includes :
Mild Steel Zinc Plated Weld-on Adaptor
Aluminum Weld-on Adaptor
Spring Adjusting Packer Washers
Installation Guide
For custom turbo applications, the TurboXS Blow Off Valve Type H is installed directly into the connecting pipe running between the turbo and the throttle body housing. We have vehicle specific adapter kits for most OEM turbocharged cars as well as adapters to mount our valve on some of our competitors flanges on our Blow Off Valve Kits and Adapters page.
NOTE: This valve is Really F'n Loud! Do not get this valve unless you want to be noticed!
I paid $175+$40 for the adapter unit +shipping $200+shipping and it's yours
e-mail:
Krayziedc702899@aol.com
