Question about Short Shifter Removal - Need answer fast! (m)
Old Nov 21, 2002 | 06:22 PM
S4rnicate's Avatar
New Member
Default Question about Short Shifter Removal - Need answer fast! (m)
Does the factory shifter use the aluminum bushings under the guide rails. There were only 3 with the SS kit, so if they do use them where do they go? They are essentially spacers that raise the guide rails up. I'm thinking that the factory shifter does not use these, but I'm not sure.
Old Nov 21, 2002 | 06:28 PM
S4rnicate's Avatar
New Member
OR... Does anyone have the Bentley printout of the shifter schematic?
Old Nov 21, 2002 | 06:37 PM
M3KILR's Avatar
Default which kit...I have the tanoga and the bushings are not needed for the stock shifter..but.......
there should be four spacers though, if were talking about the same thing?
Old Nov 21, 2002 | 06:47 PM
ed@4induktion.com's Avatar
Former Vendor
Default no, the stock shifter assembly does not use the spacers/bushings that the guide rails rest on...
the rails rest right on the metal washer attached to the "bin". is this what you are talking about. this pic is from rs4.org's instructions on the installation of a tanoga ss. these are spacers which are part of the ss kit.<ul><li><a href="http://www.rs4.org/rs4/rs4-fearture/tanoga-shifter/tanoga-p04.htm">http://www.rs4.org/rs4/rs4-fearture/tanoga-shifter/tanoga-p04.htm</a</li></ul>
Old Nov 21, 2002 | 06:49 PM
S4rnicate's Avatar
New Member
It is a UUC SS
Old Nov 22, 2002 | 04:30 AM
raveman7's Avatar
Default mmmm short shifter --- mmm good
<img src="http://pictureposter.audiworld.com/28085/neuspeed_ss.1.jpg">
Old Nov 22, 2002 | 05:11 AM
Blitzkrieg's Avatar
Default You don't need a short shifter you just need
Blitzcream
JasonS4+Festicle
11
Jul 15, 2002 02:59 AM
Skrill (RexxKw0nDo)
May 22, 2002 02:31 PM
S4ORCE1
Feb 13, 2002 02:10 PM
HIS4
Jan 31, 2002 10:50 PM
turbolag
Mar 19, 2001 03:53 PM
