Do I need anything special to change brake pads?
Old Aug 28, 2003 | 09:16 AM
Tomasz@Startup's Avatar
Default Do I need anything special to change brake pads?
I know that for the rear I will need some kind of a tool to put the pads back in. As to the fron, Bentley mentions some hex scres that I am supposed to have new. Anyone know how to get these?
I have new pads, and normal toon (inlcuding rear brake tool). Do I need anythig else?
Tomasz
Old Aug 28, 2003 | 10:06 AM
O.W. Kenobi's Avatar
Rest In Peace
You don't need any special tools for the front pads.
Old Aug 28, 2003 | 10:12 AM
mpwolf's Avatar
AudiWorld Expert
Default Changing stock pads:
1. Break wheel lugs.
2. Jack up car and support with jackstand.
3. Remove wheel.
4. Unclip spring clasp on top of the caliper with a pair of pliers. (I've found chanel locks to be very helpful here)
5. If they are your original stock pads stick a flat head screwdriver between the backing plate and the caliper to break the adhesive.
6. Unclip brake pad sensor harness, you a small flat head screwdriver to unclip it.
7. Pull out pads.
8. Reverse the above process with the new pads on.
Old Aug 28, 2003 | 10:18 AM
WindyCityS4's Avatar
Default For the rears, you will need a "narrow" 15mm wrench,
Try a bicycle pedal wrench. That is what I use. About $10 from a bike store.
Old Aug 28, 2003 | 11:00 AM
ed@4induktion.com's Avatar
Former Vendor
doesnt he have StopTechs ?
Old Aug 28, 2003 | 11:15 AM
mpwolf's Avatar
AudiWorld Expert
Default There I go not reading sigs again. In that case, add a pry bar, hammer, and hex wrench with a
breaker bar to the mix. The jaws of life that firemen use to extract people from wrecked cars might help too. ;-)
Old Aug 28, 2003 | 12:56 PM
Driving Excitement!'s Avatar
You need skills ;-) I can do a side in about 10 minutes.
Old Aug 28, 2003 | 02:06 PM
Default Great, I was hoping to do it at a track for a first time...
Hopefully there will be some skilled people at Pocono this weekend!
T
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 28, 2003 | 02:14 PM
mpwolf's Avatar
AudiWorld Expert
It's not difficult, but it can be a PITA if things stick like mine like to.
DutchDoofus
9
Sep 5, 2008 11:28 AM
kazino21
Audi A3 / S3 / RS 3
Jun 25, 2003 05:59 AM
Ghant TMK
Mar 16, 2003 06:07 PM
fshams
Feb 14, 2003 04:30 AM
GTEJR
Nov 14, 2002 04:56 PM
