MTM Springs/OZ Rims
Old Aug 28, 2003 | 07:08 PM
fastyellowcars's Avatar
New Member
Default MTM Springs/OZ Rims
I have MTM springs on my 2001 S4 with a 3 degree negative camber kit. Currently, riding 18X8 OZ Superleggera rims. After speaking directly with OZ Racing, I have 2 18X9's on the way for the rear. Two questions - will they fit stock or am I rolling the rears too (had to do the fronts w/ the camber kit but it handles like a bi*#h) and what is the correct tire sizing for the quattro?
255 rear/225 front?
Old Aug 28, 2003 | 07:18 PM
Rob O's Avatar
Huh?
Old Aug 28, 2003 | 07:21 PM
New Member
Did you miss something?
Old Aug 28, 2003 | 07:33 PM
mpwolf's Avatar
AudiWorld Expert
I have the same question as Rob. Huh? Engrish prease.
Old Aug 28, 2003 | 07:42 PM
New Member
Default Sorry - long answer.....
2001 S4 w/ MTM springs. Then, put on a negative camber kit in the front w/ 18x8 OZ superleggera rims. Negative camber + lowered + 18" rims = rubbing. Therefore, roll front fenders + repaint fenders = $3,500.00 Now, putting 18x9 OZ's on rear (staggered rims) and need to keep the tire spin the same so as not to burn up the quattro. To keep the spin the same, what is the correct tire sizing? I am hearing 255/?/18 on the rear and 225/40?/18 on the front.
Old Aug 28, 2003 | 11:09 PM
Rob O's Avatar
Default Why $3,500 to roll fenders? $100 or less to rent a fender roller, or free using a baseball bat.
As for tire size, just make sure the rolling diameter remains as close as possible between front and back. There are plenty of "tire calculators" online (google it) that allow you to calc the diameter of various tire sizes.
If you go with standard 225/40/18 up front, the rears need to be 25.08" (calculated as: ((225*.40)*2+457.2)/25.4). So 255/35/18's would probably be close enough, at 25.02"
Old Sep 1, 2003 | 10:10 AM
New Member
Default Rob O - Thanks for the calc and...
...because I didn't know about the roller (too new to AW) and so I did it myself and cracked the paint (Fu#$) - so, I had to go to an aftermarket Audi specialist and have everything re-done and painted the fenders! PITA.
Old Sep 1, 2003 | 10:26 AM
Rob O's Avatar
d'oh!
 Pouria Savadkouei
 Michael S. Palmer
Omega Supreme
Jun 15, 2008 05:03 PM
WorkInProgress
Wheels & Tires Discussion
Mar 23, 2008 12:05 PM
quattro_silver
Sep 14, 2005 04:59 AM
S4-1
Nov 19, 2003 12:26 PM
bigbad
Oct 10, 2002 06:01 PM
