Who is running
Old Aug 29, 2003 | 04:56 AM
zeus1's Avatar
Default Who is running
A Box 93 program with K04's? if so did you need a 5.0 bar FPR..what other modifications did you have to do? how has the car run since? thanks
Old Aug 29, 2003 | 05:20 AM
dscottjr's Avatar
Default there are different people running different setups. Piggie's setups as of late have been x-chip,
4 bar (stock) fpr, and an mbc to limit boost and avoid the throttle cut.
some are running apr v5.0 with a 5 bar fpr.
Old Aug 29, 2003 | 05:40 AM
zeus1's Avatar
Default Re: there are different people running different setups. Piggie's setups as of late have been x-chi
i have heard about the x chip running with K04's just anticipating my K03's going south and want to see if i can get away with my current set up running K04's..don't want to put K03's back in..
Old Aug 29, 2003 | 06:28 AM
Naptown::KckblAlstr's Avatar
Member
Default My car is running fine. I have an A-box APR v5.0 with 5 bar (not sure if its necessary) Piggie....
Pipes and a VM3. I have done some logging and talked to APR about the K03 software on K04s. I told them that I was running rich (no EGT's above 700) and they basically told me to stick with the stock 4 bar FPR. I still have the 5 bar because I'd rather run rich than take the chance at leaning out the car. I think the car in stock mode pulls almost as hard as a K03 chipped car. I like the chipped mode especially though...but I'm trying to save my clutch (stock) so I'm leaving it in stock mode most of the time. The car feels VERY smooth. I really have no complaints other than my tiny *** stock ICs.
Old Aug 29, 2003 | 06:46 AM
zeus1's Avatar
Default Re: My car is running fine. I have an A-box APR v5.0 with 5 bar
do you think version 3.3 would work with this set up? did you ask apr about using 3.3 on that set up. did the K04's bolt right up?
Old Aug 29, 2003 | 07:37 AM
Member
Default I had APR v3.3 for about 2 weeks with K04s...didn't really like it
Now that I've updated, its a lot nicer (read: smoother). As far as the K04s bolting up...I believe you are supposed to (well I did) buy the piping kit (usuallyt 300 bucks) unless it comes with the K04s you are buying. This is the inlets/gaskets/seals and whatnot. Some companies charge about 2400-2500 for everything and some other s charge 2000-2100 for the turbos and then sell the piping kit separate. ECS does the latter. I ordered mine from Brian...great shop over there...prompt and friendly.
YUM18T
Jun 25, 2006 10:31 PM
pac1085
Feb 20, 2006 01:45 PM
KRS@AW
Apr 19, 2005 11:38 AM
cgerard
Feb 20, 2005 06:45 PM
OldSkewS4
Oct 30, 2003 05:44 AM
