Left low beam not working, help needed.
Old Aug 29, 2003 | 11:32 AM
Tomasz@Startup's Avatar
Default Left low beam not working, help needed.
I changed the Xenon bulb as well checked the fuses. Fuse 21 - Left Low Beam is fine, and I installed a new bulb. Anything else I should check before I bring it to the dealer. I am out of warranty.
Tomasz
Old Aug 29, 2003 | 11:43 AM
System_S4k's Avatar
Default Look here......
<center><img src="http://pictureposter.audiworld.com/23081/p1010130.jpg"></center><p>See the little black things on the end of the wire? Those can short out and kill your lights. Happened to my euro's. Not sure where you can get the part though... I had to hack it off my stock headlights (as shown...).
Old Aug 29, 2003 | 11:45 AM
Do they Euro HOUSINGS come with it, or the hosuing is just the plastic part?
Old Aug 29, 2003 | 11:58 AM
randy@5280's Avatar
Member
Default Same problem with mine....
Passenger side light will cut on/off every once in a while. If I tap on the housing lens, the light will come back on.
Wonder if this part is available a la carte?
Old Aug 29, 2003 | 12:02 PM
System_S4k's Avatar
Default You should try borrowing another S4's housing.......
If it works, the little black part shorted. New euro's would be a good solution if that is your problem (they do come with). Stock housings look like *** anyway....
Old Aug 29, 2003 | 12:05 PM
System_S4k's Avatar
Default I have never talked to anyone who has found that part. :-/
I would imagine you could order it at a dealer, but I have never tried myself.
You could look around at local junk yards, I am sure you could find a housing out of an A4/S4... Spare parts are always good to have around.
Old Aug 29, 2003 | 12:11 PM
randy@5280's Avatar
Member
Default Hmmmm... Don't see it in the ETKA with a specific part number...
Yeah... I think you're right. Salvage yards here I come....
Old Aug 29, 2003 | 02:49 PM
OK, ECS sells Valeo Euro Housing - will this do it?
 Pouria Savadkouei
 Michael S. Palmer
racer
Aug 17, 2005 09:06 AM
oops
Aug 7, 2002 08:13 AM
Black'01S4
11
Jul 10, 2002 07:00 PM
thisisCP
Sep 5, 2001 01:50 PM
BIG NIPPER
Jul 24, 2001 04:58 AM
