Going to try to repair my underbelly cover tonight, any advice for getting it off?
Old Aug 29, 2003 | 12:09 PM
Stealth4's Avatar
Default Going to try to repair my underbelly cover tonight, any advice for getting it off?
someone said its not as easy as it seems. I have not looked at it yet. When I do I will just put the car on two jack stands in the front. What tools will I need?
im going to try to repair it with JB weld. apparently now it flaps real bad at high speeds.
Old Aug 29, 2003 | 12:19 PM
Blown Nogaro's Avatar
Default It's really easy...anybody can do it...all you need is a quarter or short flat screwdriver...
there are 10 screws, front 3, back 3 and 2 on each side of wheel wells...
Old Aug 29, 2003 | 12:20 PM
GrandPaJohn's Avatar
Quarter?? I must be a cheap bastard, I use a penny :-)
Old Aug 29, 2003 | 12:21 PM
S4_Cinci (I S'edTFA)'s Avatar
Member
Default You talkin' 'bout the plastic belly pan in front? Couldn't be easier to take off, you can use ramps
or jackstands. All you need is a wide flat bladed screwdriver and a quarter (for the plastic fasteners in the wheel wells). 10 fasteners total: 3 along front edge, 2 in each wheel well, and 3 along the trailing edge. All the metal ones are dsuz-type 3/4 turn and the ones on the trailing edge are held in with washers so they stay attached to the cover. The JB Welding portion will be the hard part!
Old Aug 29, 2003 | 12:26 PM
Stealth4's Avatar
Default thanks man, I just remember when I asked b4 someone said it was hard.
i have jackstands, when I get it off i can see how back the cracks are, if they are really bad ill just have to spend the $100+ to get a new part.
Old Aug 29, 2003 | 12:28 PM
Stealth4's Avatar
Default the two on each side of the wheel wells have no screws in them I dont think
noticed them when i was cleaning them for a show and had the wheel off. if that is the case then that might explain a lot of the flapping.
Old Aug 29, 2003 | 12:29 PM
DocSlow (Mini Pig)'s Avatar
Elder Member
Yea, I would get some screws for that mkay
Old Aug 29, 2003 | 12:32 PM
mpwolf's Avatar
AudiWorld Expert
Default Here's some advice, if you need advice to get it off, don't try to fix it. It's really simple
though.
 Pouria Savadkouei
 Michael S. Palmer
Oh yeah, if you don't have screws there, your belly pan will flap like a pelican!!!
Old Aug 29, 2003 | 12:34 PM
Elder Member
Default It is good to try things. If he asks and gets a good explanation on how, why not try it?
I have to agree that it is pretty self explanatory though.
