Are there any negatives to a stud conversion? Getting tired of fumbling with the wheel bolts.
Old Sep 1, 2003 | 04:20 AM
GrandPaJohn's Avatar
Old Sep 1, 2003 | 04:31 AM
FrankS's Avatar
Default I don't think so. jyoteen did it and never mentioned downsides that I'd seen.....
He got them from 2bennett.<ul><li><a href="http://www.2bennett.com">http://www.2bennett.com</a</li></ul>
Old Sep 1, 2003 | 05:23 AM
RKA's Avatar
RKA
AudiWorld Uber User
Default WYSIWYG on the A4 forum got his from 2bennett as well.
You can also get a metal version of the plastic stud in your emergency kit...the one you screw into the hub to keep the bolt holes aligned, and guide the wheel into place. The metal version is nice because it can support the weight of the wheel.
Old Sep 1, 2003 | 05:26 AM
O.W. Kenobi's Avatar
Rest In Peace
Default Do you use the plastic "stud" that's in the toolkit? That's all you really need.
Changing wheels is not all that difficult. Once the wheel is on that "stud," just push it onto the hub, and hold it with one hand while threading one of the real bolts with your other hand. Once that real bolt is on there, the wheel isn't moving.
Old Sep 1, 2003 | 05:51 AM
Default I just checked pricing on studs.
For $150, I'll keep using the bolts :-(
Old Sep 1, 2003 | 06:23 AM
scott12v@pghaudi's Avatar
Default I have converted both of my cars.
The only negatives are:
1. Wheel sStuds stick out slightly so they don't look quite as good as wheel bolts.
2. Wheel studs can develop a layer of rust that's needs brushed off occasionally. I'll probably coat mine with something but haven't gotten around to it.
You can order them online from ECSTuning. Do a search for the post by Jyoteen on what size to get and how to install them.
Old Sep 1, 2003 | 06:39 AM
mpwolf's Avatar
AudiWorld Expert
Is that $150 for all 4 corners, or $150 per corner? If it's all 4, it's definitely worth it.
Old Sep 1, 2003 | 06:50 AM
Bruce M's Avatar
Banned
Downside is less cursing and back pain..if you like those. Check ECS...about $80 for all 4 corners
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 1, 2003 | 07:04 AM
mpwolf's Avatar
AudiWorld Expert
Plus about $50 for nuts...I didn't know is was that reasonable. I'm seriously considering it.
Old Sep 1, 2003 | 07:13 AM
Bruce M's Avatar
Banned
A "must have" if you swap tires at the track, or do your own winter/summer changeover
