IC Misters: IAT Logs... FATS (Stock ICs w/misters)
Old Apr 18, 2005 | 10:17 PM
-M3=Lunch-'s Avatar
Member
Default IC Misters: IAT Logs... FATS (Stock ICs w/misters)
Tested out my IC misters today. It reduced my IAT while running by a whole 10*C!
I had been logging all evening. I did the a run without them on and I peaked at 48*C IAT. I then did a second run (which would be hotter) and my IAT's peaked at 39*C. I thought that was pretty cool. It also took a solid .15 seconds off my FATS time. I am running 17psi now on stock ics, its warm out so my timing is way down, but consistant 4.3s...not to shabby... IC misters are a good cheap alternative until you can get real ICs (rs4, awe).
Old Apr 18, 2005 | 10:39 PM
Imolavirus@BuehnEngineering's Avatar
Default what IC misters are they? what triggers them to spray?
heat is a killer
Old Apr 18, 2005 | 10:45 PM
Swank4's Avatar
What about misting the RS4s or AWEs? Wonder if that helps even more.
Old Apr 18, 2005 | 10:50 PM
-M3=Lunch-'s Avatar
Member
hommade, $20, stealth, the fog light button triggers them. STEALTH
Old Apr 18, 2005 | 10:52 PM
AudiS4guy - NorCal's Avatar
Member
Default Hey so is your car running better now? *ping* I'm assuming you running with the MAF on now?
IC misters work...but people never belive me =/
Old Apr 18, 2005 | 11:33 PM
Member
lol, same setup as me! I use to have the module but I sold it and went ghetto style =)
Old Apr 19, 2005 | 04:24 AM
LI-S4's Avatar
Default I am about to do this...Can you post some details?
I was planning to do the setup with the seperate fluid bag installed next to the battery and one jet on each IC...but I'd entertain other setups..
I'd like to use a dedicated switch instead of the fog switch but I'd like to see how you piped them and where the jest were installed...
TIA!
Old Apr 19, 2005 | 04:40 AM
RS_F-Whore's Avatar
New Member
Sounds good - what did you get for your $20 - seems good value?
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 19, 2005 | 07:04 AM
Visti's Avatar
Member
Agreed with the dedicated switch. I as well would like details
Old Apr 19, 2005 | 07:09 AM
SAC-CA-GTI's Avatar
Senior Member
Default So you're saying use no module? I will be putting my Avalon kit in next month just...
in time for the hot Sacto. summer. Should I just wire a switch in, then just use a throttle switch? Kind of like using naaaaawwwwzzzz. Or wire in the complete system. I just don't want to have to be pushing a switch all the time on the dash. That's kind of annoying.
