Hey BeatTheWRX, or anyone else that's had troubles with their rattling glovebox....
Were you successful in eliminating the rattle? If so, what was it and what did you do.
Seems as though mines F'n worse now. Getting really annoyed with it.
If I open it or push on it while driving, it will stop.
I did the "typical" fixes that are suggested in the archives, but to no avail.
Curious if anyone has actually pin-pointed the rattle or not....
Thanks... : )
This car's rattle though was quite a mystery. I tried everything, from rubber weather stripping all the way around the glovebox, to felt weather stripping, to velcro, etc.
In the end, I finally figured it out - the switch for the glovebox light was rattling as the glovebox door moved around against it. Took me forever to debug this, but once I found it the fix was kind of easy. I tried putting padding on the glovebox at the contact point, but when that didn't work, I just removed the switch from it's mounting point. The glovebox light now stays on whenever the headlights are on, but I drive so seldom at night it's not a big deal.
Hope this helps! Try wiggling that switch around and see if you can get it to rattle.
