Just for DocSlow, GIAC X lemmitweaked, 80.5% vs 120% secondary, block 031
Old Apr 19, 2005 | 09:16 AM
Nick Gustas's Avatar
Senior Member
Default Just for DocSlow, GIAC X lemmitweaked, 80.5% vs 120% secondary, block 031
back to back, no ecu reset or codes cleared. did run at current 120%, then set to 80.5%, power cycled, then did next run. Set back to 120% after, and values went back up.
<img src="http://tychl.txf.com/lemmitweaks/120secondary.gif">
<img src="http://tychl.txf.com/lemmitweaks/80.5secondary.gif">
Old Apr 19, 2005 | 09:19 AM
AudiS4guy - NorCal's Avatar
Member
proof that secondary *DOES* do something
Old Apr 19, 2005 | 09:20 AM
PSmalls::DoggieStyle's Avatar
Elder Member
And even more proof that BuffaloNogaro's WOT fueling is messed up
Old Apr 19, 2005 | 09:30 AM
Disappear lika Ghost's Avatar
Member
or maybe AMS stg5 is. :-D
Old Apr 19, 2005 | 09:32 AM
Elder Member
Default Heh, we already know that ;-)
I would say AMS stage 5 just doesn't take the tweaks, but it obviously did since LTFTs adjusted according to the fueling changes. The only thing that didn't change was the fueling at WOT near redline.
Member
yeah i don't think he's the first one to have problems with that kit. FWIW, my AMS likes more fuel.
Old Apr 19, 2005 | 09:34 AM
Elder Member
Default Hah, it's an inside joke. Ghost boy went from AMS stage 5 to PEB stage 3....
We called ghosty during our logging to try and get some info about his car when it was in AMS stage 5 configuration.
Old Apr 19, 2005 | 09:39 AM
ATH's Avatar
ATH
Elder Member
So can someone clarify what secondary does? When should it be used?
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 19, 2005 | 09:42 AM
Senior Member
Default Use it when it works and does what you want? :P
I wanted a bit leaner cruise and more fuel WOT, this seemed to work. I could be wrong, I don't log enough.
Old Apr 19, 2005 | 10:01 AM
BLK01S4's Avatar
Default Doc Secondary changes WOT right? Who would argue with
that .. I do it on my car it works ??
