Nav Plus System
Old Apr 19, 2005 | 04:41 PM
COMPUTEK::WMS's Avatar
Default Nav Plus System
I just got a complete Nav+ System with DVD player and TV Tuner I was installing just the Nav+ headunit yesterday and I kept getting locked out. I have the security code, is there a certain way you enter it or do you have to enter it twice, or do you need the car off or on, etc. Someone please help. This is going in my 2001.5 S4 Nogaro Blue
Old Apr 19, 2005 | 04:50 PM
PlanB's Avatar
Default Is the wiring hooked up correctly? If the power wire and ignition turn-on wire are switched
it would be losing power everytime you turned the car off.
Old Apr 19, 2005 | 04:52 PM
Default Re: Is the wiring hooked up correctly? If the power wire and ignition turn-on wire are switched
Yes wiring is fine, it turns on I just need to find out if there is a certain way of entering the security code.
Old Apr 19, 2005 | 04:57 PM
Marc911's Avatar
Default There is a SAFE wire that needs 12v constant, that is your problem
<center><img src="http://www.nav-plus.com/instructions/images/wiring1.jpg"></center><p>
Connector 3 (8 pin):
PIN 5
Make jumper from +12 on pin 7 of same connector.
Must have +12 to operate Nav.
email me if you need help
marc AT typ911 DOT com<ul><li><a href="http://www.nav-plus.com/instructions/installb5.html">You need 12v to the SAFE wire!!! (dont ask me how I know) </a></li></ul>
Old Apr 19, 2005 | 09:59 PM
Casey's Avatar
Turn the right hand **** to the number.. push **** in to enter.. repeat...
Old Apr 21, 2005 | 05:51 AM
Shap's Avatar
Junior Member
DVD player or DVD Navi? If DVD navi where did you get it!
perdido34
A4 (B8 Platform) Discussion
9
Jan 29, 2010 08:04 AM
COMPUTEK::WMS
Apr 20, 2005 11:19 PM
stupidrobothead
Mar 11, 2003 07:13 AM
dcm
Feb 7, 2001 06:30 PM
dcm
