Noob question: Has anyone considered replacing the wheel well liner (more)
Old Apr 19, 2005 | 07:47 PM
tusca's Avatar
Junior Member
Default Noob question: Has anyone considered replacing the wheel well liner (more)
with something a bit more permeable, maybe like geonet (it's an HDPE mesh with looks similar to the RS4 grill inserts but has a much tighter spacing) reiforcing a screen mesh?
As I understand it, the ICs get their air from both the lower grill and the slots in the wheel well liner. By opening up the wheel well liner a bit, you would be exposing a larger volume of cooler air to the ICs.
Secondly, for those running a Darintake, you would get a better source of cooler air.
I understand the disadvantages of replacing the liner, but for those of us who live in So Cal, it is an option.
Just a thought.
Old Apr 19, 2005 | 07:59 PM
2000SForce's Avatar
why not just take it out?
Old Apr 19, 2005 | 08:11 PM
rktskicar's Avatar
2nd. Just get rid of it...
Old Apr 19, 2005 | 08:14 PM
tusca's Avatar
Junior Member
Default The tire will kick up debris into the compartment behind the liner. Remember that the IC (more)
is in there. Water will also be thrown into the compartment if you drive in the rain. While water is not that big of a deal, will cover the compartment in muddy water. You may have a slight problem if you are running a bottom facing darintake.
Old Apr 19, 2005 | 08:18 PM
2000SForce's Avatar
then you need a fine mesh. rs4 style mesh would be to big
Old Apr 19, 2005 | 08:19 PM
rktskicar's Avatar
Been running without a liner for some time..... No problems.
Old Apr 19, 2005 | 08:25 PM
tusca's Avatar
Junior Member
Would not use an RS4 mesh. However, it sounds like removing it is fine.
Old Apr 19, 2005 | 09:06 PM
JBear::FATS's Avatar
Senior Member
Default I've seen this on a few cars, one that comes to mine was 2000 S4 driven by EDDYFIT (Custom plate),
some of the old timers may remember him. He removed the liner and replaced it with a tight mesh. Being in SoCal it wasn't a problem.
 Pouria Savadkouei
 Michael S. Palmer
Mr. Head
Nov 8, 2006 10:59 AM
Igi
A4 (B7 Platform) Discussion
Jan 25, 2006 12:40 AM
LovinMyTT
13
Oct 30, 2004 09:34 AM
4Rings::G2 boosted::
Feb 23, 2004 05:50 AM
rex9802
Jun 27, 2003 10:17 AM
