Well, after 7 events on the ECS stage III kit that I bought used, it's time for a rebuild.
Anyway, I push these brakes pretty hard at the track, so I suppose that this is routine maintenance for such usage. I've had them for a little over a year now, and the previous owner had them for probably the same amount of time with no tracking. I'd say that's pretty good wear so far. Otherwise, they perform just fine.
Anyway, don't neglect to check your rubber when moving your piston in and out. If you spring a leak, the consequences could be dire.
