Optima Red Top installed- ->
Old Apr 20, 2005 | 04:03 AM
LI-S4's Avatar
Default Optima Red Top installed- ->
Woke up to a beautiful day yesterday morning, and decided to go get bagels and prey on the locals a bit...
I'm on vacation this week so I was in no rush...but when I turned the key....bbbzzzzzz...clickety, clickety, clickety.... Nothin'....
Battery took a crap, at 220 miles shy of 50,000. I needed to get up and running (took the A4 for bagels) so after a quick search on AW for which battery to install I headed off to Pep Boys for a Red Top. They had one Red Top and one Yellow top. The Red Top was $135 and had the terminals on the correct sides, or so I thought.
When I got it home and finally got the OEM battery out...you practically need a engine hoist to lift that thing out.. I dropped the Red Top in only to find all the battery connections fit fine, but the terminals were indeed swapped...front to back.
So my impression is this...first the Optima is half the size of the OEM. I didn't weigh it but I could lift the Optima in with one hand. I have it wedged in with one of the brackets that came with the battery.
I am getting Tracksports installed tonight, so I'll work on a better bracket assembly while we have everything apart...
Old Apr 20, 2005 | 05:15 AM
Cadiburns's Avatar
Default Here's what I got....Optima 34R. Sometimes has an orange top. It has the reverse terminals for euro
<center><img src="http://www.1st-optima-batteries.com/Images/optima_34r_red_200_op.jpg"></center><p>cars.
Old Apr 20, 2005 | 05:56 AM
Oo.et.oO's Avatar
2nd that. orange top. had one in my GTi. not that terminals mattered: it was in the trunk
Old Apr 20, 2005 | 08:46 AM
HIS4's Avatar
Default Here's my Optima bracket. Not pretty but it works.
<center><img src="http://pictureposter.audiworld.com/19077/battstrap3.jpg"></center><p>
Old Apr 20, 2005 | 08:55 AM
Cadiburns's Avatar
Did you make that, or did you get it somewhere? If you made it, how?
Old Apr 20, 2005 | 09:10 AM
HIS4's Avatar
Default I made it. I forget the details of the material but...
I think it was a 1/8" thick flat aluminum bar that I got from a local hardware store. I put it in a bench vise and bent away. That why the bends look like they are rounded. I don't think you can make a square bend without cutting it and welding back together. The side shown in the picture is bolted down using one of the stock mounting points. The other side of the bar just slides under that lip that the stock battery fits under. The bar cost about $3.
Old Apr 20, 2005 | 07:19 PM
LI-S4's Avatar
Default .....
<ul><li><a href="https://forums.audiworld.com/s4/msgs/1733722.phtml">Bracket for Red Top...</a></li></ul>
A42.0rgy
Mar 11, 2008 02:13 AM
FireBirdSC
Aug 1, 2006 02:43 PM
BLKPERL
Dec 28, 2005 06:21 PM
maggio
Jan 5, 2005 02:54 PM
maggio
Jun 2, 2004 08:03 PM
