Estimated cost on installing Stasis Tracksports, Autospeed Exhaust, and a DTS. TIA
Required
Jack stands (minimum 2)
Floor jack
A ratchet
17mm deep socket (lug bolts)
13mm socket
18mm socket/wrench
19mm socket/wrench
19mm deep socket
17mm socket
16mm socket/wrench
Spring Compressor
*something to keep teh shaft from spinning as you tighten the front lock nut*
*a breaker bar or impact gun might help with really tight bolts, or corrosion issues*
Exhaust
Can't remember sizes, you'll need a Torx bit for some of the hangers, and a socket for the others. Probably can search for exact sizes. Floor jack and jack stands, 4 would be nice to get the whole car up, but 2 will probably work well enough.
DTS
I have no idea, a socket for certain, and likely a floor jack to hold the motor while you remove bolts. Floor jack and jack stands, again, 4 would be nice, but 2 could probably work.
