People w/ Samco TBBs: install question
Old Apr 20, 2005 | 01:27 PM
VandyS4's Avatar
Default People w/ Samco TBBs: install question
When you were wrapping up the install and putting everything back together, did you have a hard time reattaching the black metal plate that holds down the sensor. I guess the samco TBB didn't quite fit right in this respect, and I had to put in the screws to force it in to place, so the sensor hole is pulled over/down slightly to fit. Will this be a problem?
Also, one of the really tight 8mm nut/screw that holds that same plate to the sensor itself broke while I was tightening it. The sensor seems pretty much tight in place, will only one screw here be a problem?
er..also, there was no airbox retainer clip connected to the snorkel like there is in the tech article. Again, problem?
Now I'm gonna go fish out a bit that I dropped between the bumper and the radiator =P
Old Apr 20, 2005 | 01:57 PM
kaygee's Avatar
I twisted my sensor mount plate to make it fit correctly
Old Apr 20, 2005 | 05:35 PM
DocWyte's Avatar
Default Just ran into this. You need to rotate the samco tbb
counter clockwise to get the bracket to sit up against the mount. You want this to be a totally passive fit, otherwise when you install those allen head screws they're going to torque the sensor up and away from the tbb and create a hellacious boost leak. Ask me how I know...
Old Apr 20, 2005 | 06:15 PM
VandyS4's Avatar
Interesting. Thanks.
Old Apr 20, 2005 | 06:33 PM
VandyS4's Avatar
I won't have to remove it, right? Just loosen the big tb clamp?
Old Apr 20, 2005 | 08:23 PM
DocWyte's Avatar
Loosen all the clamps and rotate it counterclockwise, then retighten clamps.
Distinct
15
Nov 26, 2005 04:23 PM
Visti
May 7, 2005 12:08 AM
Shark_V8
Oct 10, 2004 06:33 PM
