windows arent creating an air tight seal anymore? lube?
Old Apr 20, 2005 | 01:28 PM
myfootsmells's Avatar
Junior Member
Default windows arent creating an air tight seal anymore? lube?
i can hear wind creeping through the top of the window when the windows are rolled up. any suggestions on how to remedy this?
Old Apr 20, 2005 | 01:38 PM
Pat's Avatar
Pat
Default Stuff some a thin strip of pipe insulation in behind the rubber seal.
This will bring the original rubber seal out a little bit more to seal better. Plus, you won't be able to see the pipe insulation.
Old Apr 20, 2005 | 01:42 PM
jonah's Avatar
Default Is it the door against the body, or the window against the door? if it's the door.
bend it in a bit at the top.
Old Apr 20, 2005 | 01:45 PM
Junior Member
window against the body
Old Apr 20, 2005 | 01:50 PM
jonah's Avatar
Default yeah, try twisting the door in a bit - it's metal it'll give somewhat. otherwise...
...you'd be better off adjusting the hinges rather than stuffing more foam behind the seals.
Old Apr 20, 2005 | 02:00 PM
zeus1's Avatar
silicon spray..rubber may be dried out
Old Apr 20, 2005 | 03:18 PM
Pat's Avatar
Pat
Default I've tried both methods.
I actually put washers between the hinge and body. The door just continues to sag more and more, though.
MiS4terTed
14
May 5, 2005 06:01 AM
BTTI
25
Mar 11, 2005 08:40 AM
ahmingus
Dec 23, 2003 04:04 PM
Wholsea
Aug 2, 2002 12:13 PM
Chris B
Sep 2, 1999 05:54 AM
