Metal grinding sound from LR wheel turns out to be this surprise...
Old Apr 21, 2005 | 10:20 AM
Third ROC's Avatar
Default Metal grinding sound from LR wheel turns out to be this surprise...
<center><img src="http://pictureposter.audiworld.com/11029/wheel_bolt.jpg"></center><p>How does this happen? After checking under the car and looking for suspension damage, I thought "Maybe a wheel stud came loose and is rolling around inside the wheel cap." Well, I was close except is was a bit bigger than a wheel stud.
What kind of effect does this have on my car - wheel bearing, alignment, etc.?
Any suggestion on how to get it back on? Looks like it needs a huge allen key.
Old Apr 21, 2005 | 10:23 AM
ryans4's Avatar
Default that is whack. You should get a new wheel bearing kit and replace...
<img src="http://www.ecstuning.com/stage/images/product/iadmin/2627_x600.jpg">
Have you had your car serviced recently? CV boot repair? Wheel Bearing repair?
That bolt shouldn't just "pop out"...
Old Apr 21, 2005 | 10:26 AM
MikekiM@PureMS's Avatar
Former Vendor
Default Yikes
Those don't just fall out normally. They're stretch bolts, and not designed to be reused.
Old Apr 21, 2005 | 10:30 AM
SAC-CA-GTI's Avatar
Senior Member
Default whack? <chuckling> That is whack yO! Sorry ryan...I laughed a little when..
I saw that. I can't remember the last time I heard that weard. The Kris Kross song...Whiggidy whiggidy whack! Jump! Jump! OK, no more AW for me today.
Old Apr 21, 2005 | 10:33 AM
ryans4's Avatar
you know what, I spoke to soon. Your reply is whack...
Old Apr 21, 2005 | 10:37 AM
SAC-CA-GTI's Avatar
Senior Member
Default HAHA...I know...I'm on crack today. My car finally drives straight after...
getting it aligned after f-ing up a set of tires. So i'm on high right now! Just slap me if you ever see me at an event.
Old Apr 21, 2005 | 10:38 AM
ryans4's Avatar
yeah, i really need to get an alignment, my "eyeball" toe settings can't be good for the tires...
Old Apr 21, 2005 | 10:43 AM
Third ROC's Avatar
Never had wheel bearing or CV boot for that wheel replaced - who knows how the bolt backed out.
 Pouria Savadkouei
 Michael S. Palmer
SAC-CA-GTI's Avatar
Senior Member
Default LOL....tell me...these cool settings...after FINALLY finding someone to do it...
Sitting at around 25.25 around...
Front Left Camber -2.0, Caster 3.8, Toe 3/32"
Front Right Camber -1.8, Caster 3.7, Toe 3/32"
Rear Left &amp; Right Camber -1.5, Toe 1/8"
Look OK or should I take it back and changed?
Old Apr 21, 2005 | 10:44 AM
ryans4's Avatar
I'd be concerned. How many miles? Either way, I'd' have that replaced and check the other front...
