Lance is falling behind... Updated FATS and VAG results w/ boost & TC blocks ready for analysis
Cat codes came on again yesterday about an hour after clearing them.
Thanks again for your help guys!
Weight 3780, 55 degrees F, 100 oct, MTM A-box chip, RS4 IC's, tire radius 12.7 (235-40-18)
Link to yesterday's FATS and VAG codes:<ul><li><a href="https://forums.audiworld.com/s4/msgs/1973301.phtml">https://forums.audiworld.com/s4/msgs/1973301.phtml</a</li></ul>
Do you suspect O2 sensors or intake leak?
TIME RPM MAF THROT IGNITION TIMING
27.23 4200 106.64 10.88 15.8
27.86 4400 109.89 10.88 17.3
28.48 4560 114.31 10.54 16.5
29.14 4760 118.08 10.54 17.3
29.79 4920 120.56 10.2 21.8
30.46 5080 124.28 10.2 21.8
31.14 5240 126.86 10.2 19.5
31.83 5440 128.92 9.86 21.8
32.53 5600 128.33 9.86 21
33.24 5720 129.92 10.2 21
33.96 5880 131.39 9.52 21
34.69 6040 131.31 9.52 23.3
35.44 6200 132.78 9.18 24
36.18 6320 134.00 9.18 24
36.94 6440 136.17 9.18 25.5
37.69 6600 135.31 9.52 26.3
Other possibilities for the premature knock - heavy carbon deposits? Maybe try running a fuel cleaner through. I have to think it isn't something artificial tripping the knock sensor (like motor vibrations, etc.) because you were able to raise the knock threshold with 100 octane, but it is still lower than it should be.
