Would a bad swaybar link make the steering feel "squirrely"?
Old Jan 11, 2006 | 08:43 AM
Christian (Stage Ow)'s Avatar
Default Would a bad swaybar link make the steering feel "squirrely"?
I'm trying to indentify what may potentially be failing control arms, but when I wiggle the wheels with the car on a jack, I don't see any movement. I'm at 91,000 Miles.
The car feels less sure footed. I'm wondering if it could be a swaybar link?
I know control arms are a maintenance item, so I'm not opposed to ponying up for them. I just don't want to replace something that isn't broken (right now).
Thoughts?
Old Jan 11, 2006 | 09:29 AM
WindyCityS4's Avatar
Might be tie rod ends as well.
Old Jan 11, 2006 | 09:49 AM
BluDemon's Avatar
Guest
Default Well if you jacked it up and tugged left and right and jiggled all around and felt and/or heard
nothing .... it could be a tire or shock issue.
Or you could have broke something that ties the whole suspension together like a sway bar bolt or something....
When control arms and tie rod ends go you can really tell by a good tug and jiggle at least in the few cases I have dealt with.
Old Jan 11, 2006 | 10:45 AM
Hm. I'll have to jack it up and try again. Thanks for the info.
Old Jan 11, 2006 | 06:43 PM
AudiS4inCT's Avatar
Default You might want to see how much play there is in your steering system. My car...
was going all over the road and I found my tie rod ends were gone. I replaced them and it made no difference in how the car drove. I found there was too much play in the steering wheel and this turned out to be due to loose steering column u-joint bearings and a steering rack that needed adjustment.
Hope this helps.
westcoast4.2
Jun 27, 2011 07:28 AM
bluenote
Jul 16, 2006 10:44 AM
nguyen1368
Mar 1, 2005 06:53 PM
Mr. Malcontent
Audi 100 / A6 (C4 Platform)
Dec 9, 2004 06:46 AM
Ex-PzKW Cdr
Audi allroad
Jul 20, 2004 08:50 AM
