S4 ecu pinout needed!
Old Jan 11, 2006 | 05:17 PM
Ringlord's Avatar
Default S4 ecu pinout needed!
Hi guys, I am almost done transplanting the 2.7t in my Coupe Quattro, but I need an ecu pinout diagram. I am getting a code 18028 which is coolant temp signal open or short, which is causing limp mode. There is a signal that is sent to the ecu by the instrument cluster, so i need to know which one that is. I searched the bentley for an hour, no pinout and no mention of the signal wire I seek!
HELP!
Old Jan 11, 2006 | 05:52 PM
Ochlockonee's Avatar
Member
Default The way I understand it, there are two thermistors in the ECTsensor. One is the G62 for the ecu and
the G2 for the gauge. Pin 93 green/red at ecu goes to the G62. The other G62 wire is brown/green and should have continuity to pin 108 which is probably a ground. These should be the only associated wires with this code.
Are you having problems with the gauge itself too?
Old Jan 11, 2006 | 06:07 PM
Ringlord's Avatar
HEY! Thanks for the reply. The guage works fine, the wiring is perfect, but on every start-up, I get the code 18028. If I clear the codes with the engine running, the car is not in limpmode for a litle while but then the code comes back and the limp kicks in. I checked resistance of the sensor and found it to be ok. I ordered a new sensor anyway, i'll get it tomorrow. BUT, I read in the bentley cd that the ecu recieves a signal from the instrument cluster.
Old Jan 11, 2006 | 06:52 PM
Member
Default I saw that part about the cluster telling the ECU how hot the motor is.
I'm a little skeptical, especially since there are 2 wires that connect directly to the ECU from the ECT sensor.
Anyway, I hope the sensor fixes the problem!
Old Jan 12, 2006 | 03:33 AM
Ringlord's Avatar
Default Re: I saw that part about the cluster telling the ECU how hot the motor is.
I'll see what happens today when i replace the sensor. If not, I have to find out what pin at the ecu the signal goes to, AND, what type of signal it is so I can simulate it.
Thanks!
quattromano
Feb 16, 2014 05:46 AM
Jeff_92S4
Audi Original "S" Cars
Aug 25, 2008 10:01 AM
AudiSport4000
May 24, 2006 04:19 PM
S4orceaudi
Apr 27, 2006 09:58 PM
Ringlord
Jan 15, 2006 06:00 PM
