replacement plastic screws for lower windshield valence?
Old Jan 12, 2006 | 08:40 AM
Andrew C.'s Avatar
25 Year Member
Default replacement plastic screws for lower windshield valence?
i went to change the cabin air-filter and found the screw heads stripped. couldn't loosen them with a philips head screwdriver because of this.
1. is there an easy way to loosen them in this state?
2. are they replaceable or do i need a whole new valence piece? anyone got a part #?
TIA! i STFA and just found a post from Hal saying he had the same issue, with 0 responses to his post.
Old Jan 12, 2006 | 08:48 AM
Tifosi's Avatar
Default *L* Looks like I am not the only one with this problem.
I checked with the dealership, my understanding is that you will have to replace the complete trim piece. They are about $50 or so. I have been trying to locate a salvage yard that may have them for less, but so far, no luck.
Old Jan 12, 2006 | 08:53 AM
MarkFank's Avatar
I have the same issue too.
Old Jan 12, 2006 | 09:12 AM
ryans4's Avatar
i show,--> 8D0 819 145 A ("clips") and 8D0 819 425 ("caps"), but neither look right...
Old Jan 12, 2006 | 09:14 AM
BluDemon's Avatar
Guest
I'm in the same boat
Old Jan 12, 2006 | 09:18 AM
MarkFank's Avatar
A few more & we can get a valance group buy!!! 8^)
Old Jan 12, 2006 | 09:21 AM
Andrew C.'s Avatar
25 Year Member
Default sounds like a plan!! :) have you guys been able to loosen/tighten them? if so, how? is it ok to
leave them loose, once you get them loose?
Old Jan 12, 2006 | 09:22 AM
ModifiedA4's Avatar
Banned
they're not availible separately.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 12, 2006 | 09:31 AM
Christian (Stage Ow)'s Avatar
Default The head is stripped on my far passenger one from pollen filter replacement. I keep it loose.
Haven't had any problems or noise/vibration so far. I'm going to replace it at some point just because, but it's been like that for 8 months or so.
Old Jan 12, 2006 | 09:38 AM
Ron_C's Avatar
Same - I stripped one of mine and just left it loose. So far, so good.
