Need help from those with GIAC chip knowledge.
Old Jan 12, 2006 | 04:09 PM
Ochlockonee's Avatar
Member
Default Need help from those with GIAC chip knowledge.
I bought a "GIAC chipped A box" from the classifieds and the ecu was DOA. There is water damage evidence. Also the actual chip and it's placement are suspect to me. Tell me what you guys think.
<img src="http://pictureposter.audiworld.com/72863/image004.1.jpg">
This post in the archives has pics of where GIAC places their chips compared to ams/mtm/abt.<ul><li><a href="https://forums.audiworld.com/s4/msgs/1393696.phtml">https://forums.audiworld.com/s4/msgs/1393696.phtml</a</li></ul>
Old Jan 12, 2006 | 04:21 PM
Snow Trooper Is Numb's Avatar
Junior Member
i have seen many giac in the same spot
Old Jan 12, 2006 | 04:28 PM
Member
Default I put it on my MTM socketed board and it worked but timing never went above 2 degrees.
The car is very slow.
Old Jan 12, 2006 | 05:30 PM
Member
Don't K03 chips have the software revision written on it? Mine has the ecu part# on it.
Old Jan 12, 2006 | 06:29 PM
ed@4induktion.com's Avatar
Former Vendor
Default the chips location looks fine...that doesnt mean there couldnt be a bad solder
connection causing a problem or perhaps the blacking locking rings is not fully seated. Although water damage cant be a good sign. Do you have any pics from the sides ?
Old Jan 12, 2006 | 06:31 PM
Former Vendor
Default you could have a stock file on that prom...
if so, it wont run through a GIAC encrypted socket.
Old Jan 12, 2006 | 07:21 PM
Member
It requests over 1 bar of boost, but I tried an XRV07A chip in the board and it woudn't start.
Old Jan 12, 2006 | 07:55 PM
Mike2kS4's Avatar
Default That looks like the proper encryption board...
Look for a glue-covered chip on the flip-side.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 13, 2006 | 07:04 AM
Former Vendor
hmmm....do you know the XR prom is good ?
Old Jan 13, 2006 | 07:46 AM
Mark@AutoSpeed's Avatar
Banned
Can you VAG the ECU? Any Codes?
