Bought zoldman 02 for fronts... About to go put them in.... Anything specific i should know?
Old Jan 13, 2006 | 11:47 AM
boxster02's Avatar
Default Bought zoldman 02 for fronts... About to go put them in.... Anything specific i should know?
Is it easy to find/get to the wiring harness to unclip the old sensors?
Any advice would be appreciated.
Note: I have removed the sensors from the downpipes, but never unclipped them from the harness too..
Thanks
Jordan
Old Jan 13, 2006 | 11:50 AM
JBear::FATS's Avatar
Senior Member
Default Unclipping from the harness is the simple part. I use a crowsfoot attachment
to bust mine loose.
Old Jan 13, 2006 | 12:03 PM
Dr. Jekyll's Avatar
Default 2nd on all points
2' extension w/ a flexible joint thing helps too.
Old Jan 13, 2006 | 12:06 PM
Jms3's Avatar
Default Mine just arrived yesterday, so I'll be doing this, too...
I even bought a set of crow's feet for the job.
Please post any problems you incur.
Old Jan 13, 2006 | 12:07 PM
boxster02's Avatar
Yea... i used the 3' ext with swivel to a crow's foot last time... we will see how it turns out
Old Jan 13, 2006 | 01:11 PM
gandolf the white's Avatar
Default if one is stuck crow's foot might not work i welded 2 sockets together then cut a slot for wires
you have to cut the square drive portion of the first socket off then wled that to the other no you have a super deep socket...then cut a slit to fit the wires in OR if its a real pos then cut the wire from 02 sensor as it will allow the socket to seat better.
anti-sieze compound.
Old Jan 13, 2006 | 01:24 PM
Swank4's Avatar
Actually, Vast labels their fronts L and R too. I installed mine directionally as labeled.
Old Jan 13, 2006 | 01:35 PM
Dr. Jekyll's Avatar
zoldmans come all anti-siezed up :-)
 Pouria Savadkouei
 Michael S. Palmer
Z-Tuned (Alex)
14
Aug 5, 2007 09:53 AM
dkarten
Feb 6, 2007 07:49 AM
Karrera4
Jul 16, 2005 04:37 PM
airmax617
Feb 5, 2004 09:22 PM
|skolnick
12
Jan 28, 2004 10:05 AM
