S6 vs. M5 vs. XJR comparison in EVO
Both ways there is a 9 tooth pinion. All you have to swap is the ring gear (35 tooth to 37 tooth). The rear diff is easy to remove, and I think you can swap the front without removing the transmission. If you get old gears, then you should replace the pinion too since they will likely make noise otherwise.
Todd W
This car is geared to go 155MPH at 4600 RPM all day long and use less gas than otherwise. My mileage is bad enough (15 MPG, spirited driving, some town some highway) so another 1 or 1.5 MPG doesn't make a difference to me. I WANT MORE ACCELERATION! What can I do?
If you were looking for acceleration, I still can't figure out why you didn't go with a chipped, 2.7T, 6spd. Eibach springs with struts would of given you the hunkered down feel you're looking for. Alot easier to do then changing drive ratios and cheaper.
In a high-torque car like this the complementary wear issue is the main reason to replace both sides of any cogset assembly, I've been told by several different tuners.
