The remote keys
Old Apr 18, 2000 | 06:46 PM
oskidunker's Avatar
25 Year Member
Default The remote keys
Anyone else having trouble with these keys. Mine keeps breaking. On my third one
Old Apr 19, 2000 | 06:03 AM
ChrisS -2008 A6-4.2's Avatar
Default Re: The remote keys
Breaking how? electrical or mechanical?
Old Apr 19, 2000 | 04:52 PM
oskidunker's Avatar
25 Year Member
THE PLASTIC BREAKS WHERE THE KEY RING FOR YOUR OTHER KEYS ATTACHES.
Old Apr 20, 2000 | 05:06 AM
Frank C@work's Avatar
New Member
Default Don't use it that way
It was really designed as a self-contained unit, not to hold other keys (so my dealer advised). I know it's a pain - I carry it AND my other keys separately.
Old Apr 20, 2000 | 05:41 AM
Richard Solomon's Avatar
Tech Guru
Default How are you attaching?
My keys came with a swivel attached: two small rings connected by a swivelling disk, kinda like a figure 8. One ring is (permanently?) attached to the big honkin' Audi key, and the other had a standard key ring clipped to it. I removed the standard ring and clipped one side of my separable key ring to the small ring. Now my Audi switch-key is on one end of the separable ring and all my other keys are on the other end.
I've only had mine for about 2 months, but I don't see any sign of imminent breakage. If you're threading a standard key ring directly onto the Audi key, I'd agree with FrankC that you're asking for trouble. I don't know if my key arrangement (with the swivel) is "standard" or something my dealer does? It seems to work well though.<p>Richard
'00 A6 2.7TM
Old Apr 20, 2000 | 12:13 PM
Jack Orr's Avatar
Junior Member
You need to put a ring thru the hole that is much smaller than the hole. I have one of those steel circles that you thread with other stuff, and thru that I have a house key and an Audi key ring (big) that includes the four rings. If this makes sense. Two years- no problem.
Old Apr 20, 2000 | 09:55 PM
Bollinger's Avatar
Elder Member
Default mine is fine
The VW keys just have a ring on them. Audi keys (at least mine) have a swivel attached on the corner, and it appears to be perfectly safe to attach the rest of your keys there.
I do. Been fine for 5 months so far. Now if my keys didn't hit the center console when I turned left...
Old Apr 22, 2000 | 06:04 AM
I have a 99.5 A4 and a Y2k A6. the A6 key is equipped with the swival dealie described below. The A4 has (had) a small metal ring that would slip out.
The dealer claimed that the small ring is too thin. For $6 american you can buy
the swivel part from the dealer.
Be aware, that if you spread the key fob too far apart during the installation of the new swivel the batteries inside will lose contact resulting in the key fob having to be re-programed. That will require both keys and the car take a trip to the dealer. Unless you have a great dealer which will walk you through it over the phone.
One other suggestion. I trimmed off a small piece of black electrical tape, sealing both sides of the key fob together (at the point of failure) This solved the problem prior to the swivel purchase.
 Pouria Savadkouei
 Michael S. Palmer
Redd
Q5/SQ5 MKI (8R) Discussion
Oct 17, 2015 11:16 AM
gcheddar
Nov 7, 2006 11:35 AM
LEDfoot
Feb 4, 2005 11:56 AM
Dustin A4
9
Jan 4, 2002 04:31 AM
Larry Guzin
Jul 22, 1999 04:56 PM
