could be a lemon
Sorry you're having problems--it definitely sounds frustrating. I assume the driver's window will get fixed easily at your next trip to the dealer.
Here's a thought on addressing your main problem, namely the tire shake. I agree with Bart that it sounds very much like a defective tire--either out of round or with an internal belt problem. Balancing won't fix such problems.
Since your 2.7T comes with a "real" spare tire, you could try swapping it, one at a time, with each of the other tires on your car. After each swap, hit the nearest highway for a few miles of 65-75 mph running. If the vibration disappears, you've identified the faulty tire and Audi should replace it, free of charge.
The work involved isn't major, probably one morning or afternoon. And if it works, then you've solved the problem that is causing you daily frustration.
Suppose it doesn't work, i.e., the vibration never goes away. That's bad news and would imply something harder to track down, e.g., an out-of-balance driveshaft or halfshaft. A good mechanic might spot one of those by running the car on a lift and carefully watching the shafts. (A balanced shaft will run so smoothly it almost appears stationary. A bad one will often have visible movement or appear blurry. A piece of chalk held carefully up to the rotating shaft will only mark one part of its circumference, not all the way around.)
Other possibilities: Out-of-balance brake rotor (very rare), out-of-balance flywheel (very rare, and would show up at same rpm regardless of road speed). Bart's defective tire hypothesis strikes me as the most likely by a wide margin.
So, don't give up yet! Swap a few tires and see what you find out... Good luck (and let us know).
PS--What in the world is a "maf sensor"??
That's what I kept hearing from my dealer.
When the Pirelli district manager drove the car, he even claimed that the vibration is normal (?!)
Today, the dealer put a new set of 4 tires, sent them to a specialist for balancing and even changed the front rooters. I just got back from a 134km drive- the vibration is still there at 120kmh and when braking at that speed, the whole front of the car swings laterally.
I'm puzzled...
Could be that the actual wheel is slightly bent from going over a bad bump... I had a friend with low profile 17-inch wheels he was constantly replacing every 6-months or so (of course driving in NYC roads doesn't help) cause they would bend so easily going over a pothole or the wrong type of bump... Do youhappen to have low profile wheels, and sometimes drive through rough roads?? Could be one of the wheels...
