What is your favorite brand of gasoline ?
Old Apr 20, 2000 | 12:57 PM
Elmo's Avatar
New Member
Old Apr 20, 2000 | 03:57 PM
J.H@ll's Avatar
New Member
ELF
Old Apr 20, 2000 | 04:16 PM
pablo1's Avatar
Default Any major brand that has sufficient octane and the propper additives is fine. Most brands that you
see are not neccessarily refined by that brand. Usually, gas stations are independant retailers. Each of the brands you see don't have refineries in all areas so many times when you buy brand ABC you're getting gas from XYZ. What you see is not always what you get.
Old Apr 20, 2000 | 06:33 PM
Stu B's Avatar
Junior Member
Av-Gas! (106 octane :-) )
Old Apr 20, 2000 | 06:48 PM
DWP's Avatar
DWP
Exactly Correct, Pablo1
Old Apr 20, 2000 | 07:17 PM
pablo1's Avatar
Default Re: Av-Gas! (106 octane :-) )
Stu B, why would you use that? Correct me if you know anything different (maybe it has some great additive for injectors, etc.), but when you go over the octane requirement of an engine, there is no benefit to using the higher octane and priced fuel. Years ago, many regular and mid grades did not have the same detergents or additives, so to keep fuel injectors clean one was at times "forced" to fill up with premium when the engine did not require the octane. BTW isn't Av-Gas rated by the RON method rather than the R+M divided by 2 which is roughly 5 points lower than the equivalent RON (this is how gasoline octane is figured in most other countries ie. 98 in Europe is = to 93 here in the US).
Old Apr 20, 2000 | 08:49 PM
Stu B's Avatar
Junior Member
Default pablo1: it was humor :-)
Although I used to run 100 octane racing fuel in my Lotus Cortina twin-cam at roughly $5.00 per gallon!
Old Apr 21, 2000 | 09:01 AM
srosie's Avatar
Member
Default Knowing little of the chemistry, but when...
our 99 Saab 9-5 Wagon started emitting a fairly strong sulfer smell the Saab dealer recommended changing gas brands before a cat. converter replacement. Believe it or not they stated Amoco and Mobil were of similar formulae and that we ought to switch to Shell first?!
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 21, 2000 | 11:59 AM
pablo1's Avatar
Default Re: pablo1: it was humor :-)
After the excellent explanation you gave on the quattro system I really didn't believe you wouldn't know. But then again maybe you had some trick under your hood you weren't sharing with us.
Old Apr 21, 2000 | 12:50 PM
Elmo's Avatar
New Member
Did it work?
