my own 2.7T odd sound at startup
It has done this on several tanks of gas from different vendors (all 92 octane).
I'm slightly concerned, for a while I thought it was just Audi purposely knocking the engine a little at startup to heat up the cylinders faster. I read somewhere that they do disable the knock sensor for a short time at startup.
Now, I'm not so sure. Anyone else have this or care?
It basically makes your engine sound like a (quiet) diesel for 15-30 seconds at startup.
My layman theory is a partial oil blockage to a valve train component (lifter/rocker) since temperature doesn't seem to be a factor with mine. I also noticed an exhaust smell that seems to stop when the tapping stops.
My 2.7 T does not do this by the way.
I sure would like to know what this is, especially in your 2.7 T and sincerly hope it is not a major or time consuming fix (if needed).
Good luck.
..../jp
-p
See your dealer as soon as you can.
