Some surface scratches on my hood, Tip holding 1st gear, buzzing and paint in front of rear wheel.
The problem with the paint in front of the rear wheel well that HuggyBear, Stu B and April/Verdegrrl have referred to has begun very faintly on my car. It is hardly visible, but after you posted the pics I went and looked very closely and it is there in its infancy. What a drag. April please follow up with the remedy you thought may work.
I have started to get a slight buzzing at times coming from the headliner or visor that I have read about on this forum. Anyone out there with a solution?
Finally, I wanted to clock my car 0-60. I brake torqued the engine and let it rip. The tip didn't shift and I bounced into the rev limiter. My transmission is chipped as is my engine. Without brake torquing, it shifts at redline. It only ran to 6700 or 6800 RPM for a moment so I don't believe anything could have happened. My next run, 6.65 seconds. Anyone else experience this and should I worry at all about bouncing off the rev limiter.
Knock on wood I haven't observed/heard the buzzing from the headliner that has popped up on the forum yet but do seem to remember that the dealers that are hip on it DO have a solution.
I don't know what to tell you about the engine "bouncing into the rev limiter". Hopefully your momentary excursion in the "red zone" did not cause any permanent damage. But as I'm sure you have already figured out, all that torque from the 4.2 V8 could not have been too healthy for the tranny.
I'll keep my fingers crossed for you Pablo1!
I'll ask the mechanic how easy it is to remove the rear fender panels. Look for a paint shop that is used to working with aluminium panels. They have to adapt to materials that expand and contract a great deal. They should know how to treat the problems we have.
The rev limiter is there mainly to avoid frying the accessories. Most engines can easily handle 7000 to 8000rpm without those considerations.
April
I wonder if this is a side affect of your Tip chipping. I would consult with whoever did the chipping. I was going to wait another week or two to ask you how the "tip chipping" is answering your performance goals, but I will ask you now. "How is the Tip chip answering your performance goals?"
I guess Audi is going to have to address the paint pitting in front of the rear wheel wells.
