Last night while taking friends to dinner, my 4.2 died when I put the car into reverse.....
Has anybody else experienced this?
If this bothers you again, have the shifter position sensor/mechanismn checked first.
The other electronic problems were related to the NavPlus / stereo / Bose system. About four times I only heard a turbine-like sound after starting the car instead of the radio station which was on when I left the car. Also the funny "Audi..." splash screen on the center console did not show up during initialisation.
I had several occurences of such "glitches" in the electronic system of that car and (as an electronics engineer by education) I think that these are small design faults in the electronics circuitry (not enough resistant to electronic noise conditions as they are normal in a car environment - which is very demanding BTW).
What I am concerned is if sometimes - of course after warranty has expired (which is only 12 month here in Europe!) - such a glitch could damage the control system in a severe way and then it could get pretty expensive to fix...
If others also have similar problems it could be worth to start a new thread whith it?
Ernst
A6 4.2QT / black & vanille / sports package / NavPlus
We do not have NavPlus in States. Not much help there.
A friend was driving my car, he parked and could not remove the key. I jumped in and attempted to diagnose the problem.
Started the car turned it off several times. Then I grabbed the thumb lever that you squeeze before taking it out of park. It felt different, like it was half engaged.
Moved the shift lever into drive then back into park and the key was free to remove.
If I were to try and describe what I felt,
it would be as if there is a Male pin that must fit into a recepticle. When fully engaged it releases the key. It seems that my friend must of only partially released the squeeze dealie on the shift ****, causing the probe not to fully engage. There for the failure.
Once cycled all was well.
Regarding NavPlus you are right but I could think that also the standard Nav system which is avaiilable in the US has the same problem?
