Automatic windows are posessed
Old May 1, 2000 | 03:18 PM
Keith's Avatar
New Member
Default Automatic windows are posessed
My 2.7T is about one month old. Here is how it goes: (this only seems to happen after the car has been out in the sun for a while) I lower the window upon return to my office parking garage to use my key card, and then raise the window back up. The window automatically (without me doing anything) lowers back down about one quarter of the way open. I close it again, it goes back down. This goes on several times, until I am finally able to get the window to stay up. Has anyone else experienced this?
Old May 1, 2000 | 03:41 PM
Stu B's Avatar
Junior Member
Have you checked for any TSB's on the matter?
Old May 1, 2000 | 03:44 PM
Keith's Avatar
New Member
Default Re: Have you checked for any TSB's on the matter?
Sorry for the ignorance, but what is a "TSB"?
Old May 1, 2000 | 06:57 PM
pablo1's Avatar
Technical Service Bulletin
Old May 1, 2000 | 07:09 PM
JP4's Avatar
JP4
Default This is just a WAG but here goes....
My guess is that something is binding on the window mechanism or in the track causing it to "think" there is something in the way which would stop or reverse the window.
Old May 1, 2000 | 07:39 PM
DWP's Avatar
DWP
Re: Automatic windows are posessed
Old May 1, 2000 | 08:18 PM
Stu B's Avatar
Junior Member
Default Here is VoA and AoA online TSB site. I also think JP4 may be onto something also. Good luck!
<ul><li><a href="http://tech.vw.com/">http://tech.vw.com/</a</li></ul>
Old May 2, 2000 | 08:33 AM
JP4's Avatar
JP4
Default or...
The limit switch on the window is out of adjustment. In other words, when the window hits the closed position it should stay there and not "think" something is in the way. If the limit switch is out of adjustment, when the window gets to the closed position it would stop or come back down because it thinks something is in the way.
 Pouria Savadkouei
 Michael S. Palmer
Old May 2, 2000 | 09:06 AM
Keith's Avatar
New Member
Default Re: or...
Thanks. Sounds like a trip to the dealer is needed. I just wanted to see if there was a quick fix, or if I was missing something.
Old May 2, 2000 | 09:22 AM
JP4's Avatar
JP4
Agreed... If it's either one of those the service department will have to fix it.
