getting 5W-40 oil
Old May 8, 2000 | 11:08 PM
Bollinger's Avatar
Elder Member
Default getting 5W-40 oil
Don't care if it is synthetic or not. Someone on here said they special ordered it.
I want to get some since apparently my dealer (Stevens Creek/Andersen-Behel) plays a little fast and lose with the oil specs.
Old May 9, 2000 | 05:24 AM
Nomad TT's Avatar
New Member
Default My dealer put synthetic oil in my car and I think it is Castrol something. If you like..
I can ask him exactly what it is.
Chris (Nomad 2.7T)<p>2000 A6 2.7T Tiptronic
Cashmere Gray
San Antonio, TX
Old May 9, 2000 | 07:10 AM
Chris JB's Avatar
Default I switched to Mobil One 5-30
at the 8,000 mile service, and now with almost 16,000 miles, I've used less then a quart in the last 8,000 miles. I also changed the oil at 3,500 miles.
Chris JB
00 2.7TM
Old May 9, 2000 | 08:43 AM
Todd W's Avatar
Junior Member
Default I strongly suggest against Castrol Syntec
Mobil 1, Amsoil, Redline, and Royal Purple are all good synthetics. Many people share my opinion that Syntec does not work for long change intervals or for turbocharged cars. It also has a high evaporation loss.
I run Mobil 1 because of the ones I listed it is the easiest to get. 10-30 and 5-30 are great for turbos, 5-40 and 20-50 work well for NA engines in my experience.
Well we're on the topic, I would run one change of dino oil before switching to synthetic. Also, use the dealer oil filters while under warranty. After that you can mail order OEM Mahle or Mann filters. Mobil 1 and Amsoil filters are also OK, but not Fram, etc.
You do not have to switch to synthetic, but if you do please follow the guidelines I set out or at least do some research. Not all synthetics are better for your engine than good dino oil.
Todd W
Old May 9, 2000 | 02:43 PM
Bollinger's Avatar
Elder Member
Default fine, I'll stick with standard. Where do I get it?
Local places do not stock 5W-40, can I order it from somewhere? Where?
Old May 9, 2000 | 04:48 PM
eduardo's Avatar
New Member
I was also cautioned against Syntec
Old May 9, 2000 | 07:23 PM
JT228's Avatar
New Member
Default I suggest Valvoline SynPower 5W-40 - Here's Why...
Valvoline SynPower 5W-40 is the only US oil I've seen that satisfies API SJ/SH, ACEA A3/B3, and the VW/Audi 500-series specs. The owner's manual for my 2.7T recommends 5W-40 synthetic for all temperature ranges. Also, for turbo engines, I believe that synthetic oil has less tendency to "coke" due to heat than dino oil.
I had the same sort of problem in locating 5W-40. I contacted Valvoline headquarters in Kentucky and asked them to put me in touch with my regional sales rep. After a bit of phone tag, I was able to order two cases of oil directly from him. Of course, YMMV, but it worked for me.
BTW, I have no relationship with Valvoline other than as a customer.<ul><li><a href="http://www.valvoline.com">http://www.valvoline.com</a</li></ul>
Old May 9, 2000 | 09:01 PM
guyinca's Avatar
New Member
Default Some words on oil - marketing marketing... and marketing too. And some technical comparisons too
I don't own an Audi yet but if the owner's manual says to go with synth 5-40 oil then it's probably becuase it's the least liability for them to say so. Synth oil, as far as know, doesn't lubricate as well as mineral oils but it holds up better against breaking down due to heat. if you change your oil at normal intervals you'll never have a problem with oil viscosity breakdown.
Secondly, 5-40 oil will break down faster then 10-30 oil, for example because it has more additives to maintain that vast temperature range. I don't know if they still do but general aviation aircraft always used straight grade oil, like SAE 30, just for this reason - less likelyhood of a breakdown. I live in the SF Bay Area where the climate is prime for 10-30 oil. Even if you drive up in the mountains where there's snow or the desert you'll be fine with this grade. 5-40 oil is really only good in severe climatic areas like Minnesota where it can be 30 below in winter and frickin 95 degrees in summer. Again, by Audi saying to use 5-40 oil it covers their ***. And it covers their *** even further by saying you should use synth in case the turbos heat up the oil a lot and you never change the oil.
 Pouria Savadkouei
 Michael S. Palmer
Old May 9, 2000 | 09:16 PM
guyinca's Avatar
New Member
Default Some info on Prolong oil and others like it. Long.
It wasn't brought up in this posting but I thought you guys and gals might be interested in my opinions on Prolong oil and other marketers of wonder oils.
Prolong is actually a really good product that had been developed over a decade and isn't a bunch of bs like Slick 50, for example. However, it will probably not help your car at worst and help it almost unnoticeably at best. The stuff does what the Prolong marketeers say it does. If you drain your oil that was treated with Prolong you could still drive your car. However, you could save your money and just drive your car without draining the oil and you'll be better off. The stuff adheres to metal - that's why you can drain your oil and still run the engine for some time. However, your vital engine parts are continuously splashed with oil so that you don't need an adhering agent in them. Prolong has never proved that if you put their product in your engine your engine will actually last longer and wear less. That's because they can't. They can only show what happends if you drain your oil.
Don't ever use Slick 50. It's just plain oil with teflon. The teflon particles are too big and heavy to do any good on metal to metal contacting parts and eventually end up at the bottom of your oil pan.
bthirk
28
Apr 30, 2004 07:27 PM
Phil G.
Jan 7, 2004 10:39 AM
Kgnast-Nemo4.2
11
Aug 30, 2003 11:41 PM
Drew A6 2.7T
11
Mar 12, 2003 07:01 AM
cedarhills
Apr 11, 2000 08:39 PM
