Weird shifting: A6 4.2 Tip
I'm suspect, because other cars A6s I've driven didn't seem to do this (they were all 2.7Ts however). ALso, it only occurs from 2nd to 3rd.
I find it very annoying, and wonder if others have the same experience.
Bryce<p>Bryce
It's hard to describe, but generally the gear changes are not as crisp as I think they should be.<p>Bryce
Second, the electronic engine controls will retard the timing a bit and/or close the throttle somewhat and/or maybe some other things to smooth the shift. Your "slide" shifting may be due to these actions. It feels like the engine power is being reduced just before, and during, the shift (which is in fact what's happening).
Why 2nd-to-3rd only? Maybe because at higher speeds and higher gears, you're typically not on the throttle as hard. A reduction in engine power is less noticeable if it's putting out relatively little to begin with. In 2nd, however, you're typically on the gas harder than at higher speeds and any reduction will be more noticeable.
That's my theory, anyway. My guess is that your trans behavior is normal. Try experimenting with harder or softer acceleration and see if the shift behavior varies.
Finally, if the "slide" is REALLY pronounced, then maybe that's not normal and a trip to the dealer is in order. Good luck!
Then only auto shift from 2nd - 5th at red line?
BTW: I happen to think the transmission on the 4.2
is smooth as silk across the board.
Conversely, the car can only be brought down from 2nd into 1st by flooring it, as well. I have never been able to use the tip shifter to bring the car from 2nd to 1st at partial throttle or no throttle. So at partial throttle or no throttle the car auto downshifts from 2nd to 1st when your actual car speed drops below 5mph it seems. Just like at a stop sign where you almost come to a complete stop or a dead stop given the traffic.
So the tip automatically takes over a few shift points I like. So the tip chip debate has merit! I don't mind the downshift lack of control as much as the upshift at partial throttle lack of control.
Does this help or have others noticed different?
