Tinting A6 sizing
Old May 13, 2000 | 11:00 PM
S4Killa's Avatar
New Member
Default Tinting A6 sizing
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/tint%20plotter%20multi.jpg"></center><p>At XLNT Tint(Anaheim 714-630-6227), the process for the A6 2000 model tinting, starts out by a database being accessed for the window sizes on this particular car. This is fed into a plotter that will etch out the dimensions on the window tint. Each window is covered by 1 piece of tint. Not 2 or 3 pieces. Even the large back window is done with 1 piece. The plotter cuts the tint but not the backing at this point.
Old May 13, 2000 | 11:03 PM
S4Killa's Avatar
New Member
Default Re: Tinting A6 protect car
The next step is to wrap the car with a protective sheeting that keeps the car surface safe from any contact such as clothes or a hose, its just a precaution and is a nice touch.
Old May 13, 2000 | 11:06 PM
S4Killa's Avatar
New Member
Default Re: Tinting A6 protect car oops heres the pic
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/tint%20cello%20protect.jpg"></center><p>
Old May 13, 2000 | 11:12 PM
S4Killa's Avatar
New Member
Default Re: Tinting A6 clean the windows
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/tint%20window%20clean.jpg"></center><p>They then clean the window to ensure the tint goes on streak and bubble free.
Old May 13, 2000 | 11:20 PM
S4Killa's Avatar
New Member
Default Re: Tinting A6 molding the tint to the curve of the window
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/tint%20pfw%20sizing.jpg"></center><p>They work the tint first on the outside portion of the window to get it to form to the curve of your window. The backing is still in place at this point. They do this till the tint is smooth over the whole surface.
Old May 13, 2000 | 11:31 PM
S4Killa's Avatar
New Member
Default Re: Tinting A6 placing on inside of window
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/tint%20back%20view%20pfw.jpg"></center><p>They then place the tint on the inside of the window starting at the top(notice window is down a bit. They trim it up and only work the upper half of the window. The lower half still has its backing on. Also important to note is nothing is removed on the door to get the tint on the window. No removal of any panels at all! After it is in place then the lower half is worked on. Because the measurements were plotted at the start, tint size is right on.
Old May 13, 2000 | 11:38 PM
S4Killa's Avatar
New Member
Default Re: Tinting A6 back window
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/tint%20bw%20sizing1.jpg"></center><p>The back window is done in the same way as side. The one piece tint is placed with backing still on, onto the outside of window. Note: the blue plastic panels on the side walls hold the tint pieces while work is done.
Old May 13, 2000 | 11:42 PM
S4Killa's Avatar
New Member
Default Re: Tinting A6 back window #2
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/tint%20bw%20sizing%202.jpg"></center><p>Thought I would show the start of the smoothing process of back window.
 Pouria Savadkouei
 Michael S. Palmer
Old May 13, 2000 | 11:45 PM
S4Killa's Avatar
New Member
Default Re: Tinting A6 back window #3
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/tint%20bw%20sizing3.jpg"></center><p>Last one of back window. It is almost ready to be taken off and installed on the inside of back window.
Old May 13, 2000 | 11:56 PM
S4Killa's Avatar
New Member
Default Re: Tinting A6 Final Product #1
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/tint%20use%2033.jpg"></center><p>This is how it turned out. Xlnt Tint(located in Anaheim California) was very professional in their approach to window tinting. When you call ask for Mike Schuch.
