17" tires
Old Aug 18, 2000 | 10:15 AM
jb2.7t's Avatar
Default 17" tires
i know this is going to sound awfully ignorant, but does going from 16" to 17" tires affect the speedometer at all?
Old Aug 18, 2000 | 10:48 AM
RSC's Avatar
RSC
Default Re: 17" tires
It all depends on your wheel/tire combo diameter. If you wanted a bigger wheel, you'll probably use lower profile tires and the resulting diameter might not change that much.
eg size diam speed@55
185-60-14 22.74 55.00
205-55-14 22.88 55.33
Old Aug 18, 2000 | 11:41 AM
asics's Avatar
New Member
If you want to go to 17 inch wheels on a 2.7t then you need to use 235/45/17 to keep the same tire diameter. I am using this size on my A6 2.7t on 17x8" wheels. You could probably use a wheel from 7.7"-8.5" with this same tire size. Make sure the wheel is for an Audi A6 so that the bolt circle and offset are correct for the car. BBS, Ronal, Audi and others make 17" wheels that will work on the A6.
Old Aug 18, 2000 | 12:22 PM
jb2.7t's Avatar
i'm going to put the S4 wheels on...
i believe they should fit fine, and i'm pretty sure they have that diameter.
thanks for the help!
Old Aug 18, 2000 | 12:54 PM
Chris JB's Avatar
Default That's what I've done...
with no problems. In fact, I love em! Check out pictures from below, posted by Pete RD.
Chris JB
00 2.7TM
Old Aug 23, 2000 | 08:43 PM
Pete RD's Avatar
I'm running 245/45 x 17s on S6 AVUS 17" x 8" wheels. The increase in the revs/mile is + 1.44% over the stock 215/55 x 16s. The odo/speedo error is + 1.25%, so I'm just about "zeroing out" the odo/speedo error. I have the Eibach lowering springs, and there is no problem at all with fit/clearance, including aggressive driving on undulating roads.<p>Peter R Dieckerhoff
RS2Spec
A6 (C7 Platform) Discussion
Feb 1, 2015 05:24 AM
cruzan
Apr 24, 2006 09:43 AM
audiguy76
Wheels & Tires Discussion
Nov 10, 2004 08:09 AM
dlubin
9
May 18, 2003 06:20 AM
Doug2.7
Aug 28, 2000 01:47 PM
