HID headlight aiming
2. Read the link attached to this message.
3. Didn't do the reading? OK. Park about ten feet from a wall on a level surface. On the wall, mark a spot opposite the center of the low beam bulb.
4. Find the adjustment screw. It's the white plastic thing on the top of the headlight with a six sided hole and a phillips head inside the hole.
5. Adjust the headlights so that the "hot-spot" is about three inches below the mark. Just turn the screw. Which direction? The direction required; one way is up the other down. Don't remember which but I'm confident that you'll figure this out.
6. Drive around and see how you like it. See how your fellow drivers like it.
Rinse. Repeat as necessary.
If all that sounds too complex, just park near a wall and fiddle with the height. Your goal is a slightly down-pointing beam.
FWIW, from the factory, mine were adjusted to properly illuminate about three feet of road.
//Greg<ul><li><a href="http://www.humanspeakers.com/audi/headlight-aiming.htm">Aiming E-Code Headlights</a></li></ul>
