Need Help...finding Phone Antenna Lead in Headliner...
Old Aug 26, 2000 | 07:49 PM
gbjerke's Avatar
New Member
Default Need Help...finding Phone Antenna Lead in Headliner...
I'm in the middle of installing my Nokia 61xx handsfree kit...trying to find the antenna lead in the rear headliner per the Audi TSB. I find nothing...any tips or tricks I need to know???
Did Audi move the lead in the 01 models??
What's the point in pre-wiring the antenna if the lead is impossible to find???
Thanks in advance for your help.
Guy<p>'01 A6 2.8Q - Ming Blue Pearl/Melange w/Nav
Old Aug 26, 2000 | 10:38 PM
Mike4.2CBW's Avatar
Junior Member
Default Posted for the 2000 as...
<p>2000 4.2
Casablanca White / Melange
PSL, ESP, Xenon, Cool<ul><li><a href="https://www.audiworld.com/forum/m/a6/msgs/20618.phtml">https://www.audiworld.com/forum/m/a6/msgs/20618.phtml</a</li></ul>
Old Aug 27, 2000 | 07:03 AM
gbjerke's Avatar
New Member
Default Thanks...Can't find or Feel Anything So Far...
Old Aug 27, 2000 | 09:14 PM
redcat's Avatar
New Member
Default Re: Need Help...finding Phone Antenna Lead in Headliner...
I just installed the antena in my 2001 A6 a few weeks ago and posted my comments at that time. Yes there is an antena lead wire under the head liner. It is located about 2" left of center just above the window; you can locate a"lump " by depressing the head liner. I used a stiff wire hook to snare it. Previous posts have instructed how to cut a small slit in the head liner at the center of the widow; the antena is fished through this hole with some difficulty. You will also find the connector to be a mini uhf connector( at least that is what the latest FAQ called it) not the normal antena connector. I could not find an adapter or an antena that this connector would match up to and I was in a hurry to get in service so I cut off the supplied connector and put on a connector( Radio Shack ) that matched my window mount. This was a some what involved process since the main conductor is braided not stiff. If you want the gory details on how I managed to attach the connector ask. I would search for a adapter or a matching window mount if you are not rushed.
Old Aug 27, 2000 | 11:25 PM
Bollinger's Avatar
Elder Member
Default mini-UHF connector
Try your local HAM radio store for an adapter. They should have these.
Old Aug 28, 2000 | 07:43 AM
gbjerke's Avatar
New Member
Default 2" left of center...from what perspective?
When you say left...do you mean drivers side? Or left as you look rearward?
Is the lead "under" the headliner or "in" it? Perhaps I haven't cut deep enough? I haven't been able to feel any lump. How far back from the window edge of the liner was the lump 1", 2"...?
I appreciate your help. I can't worry about the connector til I find and fish out the lead!
Old Aug 28, 2000 | 05:16 PM
redcat's Avatar
New Member
Default Re: mini-UHF connector
I tried Radio shack with no luck--maybe they were out of them and the sales person didn't know what I was looking for. An adapter would be the way to go. You will find the mini- uhf connector provided is male whereas the antena wire connector needs to be female.
Old Aug 28, 2000 | 05:38 PM
Bollinger's Avatar
Elder Member
Default I wasn't thinking Radio Shack, more like a good store
We have several around this town (high geek area), but you could try www.hamradio.com or something.
 Pouria Savadkouei
 Michael S. Palmer
acapella8
Apr 2, 2007 07:27 PM
mirali
Mar 4, 2002 06:46 AM
gbjerke
Sep 1, 2000 07:31 PM
gbjerke
Aug 31, 2000 10:31 AM
gbjerke
Aug 5, 2000 08:00 PM
