Tip behavior -- first/second
Wednesday morning I started the car, drove down the hill (1.3mi) in full-auto, then flipped it into Tip as I approached the final (steep and sharp) curve, then tipped it back to third, then second. After the curve I tipped it into third for the short straight before reaching a major road. Approaching the intersection, I tipped back to second, then (seeing a solid stream of traffic), back to first (without thinking -- and it WENT INTO FIRST although I was still traveling at 10-15mph). After stopping and waiting 4 or 5 seconds for a break in the traffic, I accelerated smartly, expecting an almost instantaneous change into second. But IT STAYED IN FIRST until I tipped it into second. At the next light the takeoff was normal -- almost immediate auto change into second (in Tip).
Thursday morning, I repeated the sequence and managed to tip it into first again at 12 mph as I approached the intersection. Since there was no cross traffic, I didn't stop, but accelerated through in first and watched the tach get to 5000 at less than 1/2 throttle before I tipped it into second.
Friday, there was lots of traffic, but slow, so I changed down to first on the move again then eased into a break at very low throttle and stayed in first as we all slowly accelerated. At around 5000 I tipped it into second.
It was wonderful to feel in full control of the Tip, without its auto first/second behavior. Does anyone know why I managed to get this behavior (engine barely warm, moving downhill as I changed down...), and if there is any way to repeat it at will? Perhaps a Tip Chip could be made to allow full Tip control?<p>2000 4.2
Casablanca White / Melange
PSL, ESP, Xenon, Cool
Go figure.
- you get to about 6'300 rpm (in which case it upshifts)
- you get below about 1'600-1'800 rpm (in which case it downshifts)
- you use the kick-down feature (i.e. press the accelerator beyond the first resistance point), in which case it downshifts on you, provided this does not send the engine above 6'300 rpm
In practice, and for 1st / 2nd gears, it means that if you press the pedal to the metal, the Tip will down shift you to 1st, and this up to speeds of about 35 mph (55 kph) - try it, the shock it gives to the car certainly feels funny.
Still, with a 4.2, I don't think you would ever need to down shift in 1st gear with Tip - you have way enough torque even at low rpm and low speeds and can probably always go in 2nd gear or higher.
A.
