Break-in rules
So, how important are the break-in rules? As I understand it, the rules are:
- not to use full throttle,
- not to drive faster than 3/4 of top speed, and
- avoid high engine speeds
during the first 1000 miles or so.
How important are these rules? I don't think I will break the first two rules. It is the third one that bothers me a lot. Can someone tell me anything that would make me feel any better?
thanks!<p>sanjay
'01 BB/TG 2.7T 6-spd
PSK/cold/prem/pref
Portland, OR
I still recommend to new owners to try to break them in according to Audi, but they like to run and some high revs I don't think are gonna hurt during break in. You just don't want to be doing it all the time. Hope that allows you to sleep ;-)
Have fun and drive safe!<p><img SRC=http://home.earthlink.net/~gstahara/Graphics/Coloraudi.jpg Border=0></a>
'01 2.7T Tiptronic, Luxury, Premium, Bose, CD, Xenons
One other VERY important thing. You might already know this, but just in case...according to my dealer and many posters here at AudiWorld, it's NORMAL for these engines to burn some oil during the first few thousand miles. Check your oil at least every thousand miles and don't be alarmed if you need to add some. (Be careful to not over-fill.) The need to add oil should stop after the first scheduled change (8000 miles).
- Mike<p>mpuzach
<img src="http://pictureposter.audiworld.com/audiworldpics/2000/SigPicA6.jpg">
2000 A6 2.8Q Tip
Racing Green/Tungsten Gray
Conv Pkg/Cold Wthr/Xenons
From what I recall in the manual, I <i>think</i> you can put in regular gas, and the ECU will notice and adjust accordingly. Once the 1000 miles is done, disconnect battery for an hour or so after putting in some 92 or better gas so the ECU starts anew. I think the ECU can detect poorer gas, but not better gas.
Am I nuts?<p><a href="http://registry.audiworld.com/audi/registry/details.asp?car=5325">
<img src="http://www.cameo.net/stuff/augerspin.gif">
    2.7T 2.XS
</a>
Think about it. Say I chop off one of your arms. You'll adapt, but is it going to make things easier on you or harder?
The ECU somehow determines that you are back to good gas somehow, no need to remove the battery cable. It might speed up the process, but it's not as if putting regular gas in your car once ruins it forever.
But I don't see how it would make the engine work harder and produce MORE stress than premium gas - how can it possibly work harder and generate more stress with less-potent fuel? If I stop drinking Pepsi and switch to diet Pepsi, I'll have less energy so I won't be able to run as fast or lift as much weight at the gym, so I'll endure less physical stress.
Am I still nuts? :-)<p><a href="http://registry.audiworld.com/audi/registry/details.asp?car=5325">
    2.7T 2.XS
</a>
