Does changing to 17" wheels also affect speedometer?
Old Aug 28, 2000 | 07:15 AM
Doug2.7's Avatar
25 Year Member
Default Does changing to 17" wheels also affect speedometer?
Just curious, I know when I have changed tire sizes before, I also changed the gearing for the speedo. Any insight would be appreciated.
Doug ;}
Old Aug 28, 2000 | 07:18 AM
kaeru's Avatar
New Member
Default Re: Does changing to 17" wheels also affect speedometer?
not as long as you "plus one" the tire size. In other words, you compensate for the larger diameter wheel with lower profile tires to maintain overall diameter.
Old Aug 28, 2000 | 11:04 AM
Ira B's Avatar
New Member
The stock wheel and tire is a 215/55-16. This is almost exactly the same diameter and rolling radius as a 235/45-17. Thus, if you use this size 17", you will see no effect on your speedometer, odometer, etc.<p>Ira
2000 Tornado Red A6 2.7T (M6)
Old Aug 28, 2000 | 11:39 AM
Jack Orr's Avatar
Junior Member
Specifically: 235/45/17 results in a .01% difference- or 1mph at 100mph
Old Aug 28, 2000 | 12:57 PM
Audiablo's Avatar
Junior Member
Default Use this calculator to know for sure
<p><a href="http://registry.audiworld.com/audi/registry/details.asp?car=5325">
<img src="http://www.cameo.net/stuff/augerspin.gif">
&nbsp&nbsp&nbsp&nbsp2.7T 2.XS&nbsp&nbsp&nbsp&nbsp
</a>
<ul><li><a href="http://www.miata.net/garage/tirecalc.html">Tire swap calculator</a></li></ul>
Old Aug 28, 2000 | 01:47 PM
STEVE2.7T's Avatar
Junior Member
Default 215/55-16 vs. 235/45-17
Jack, I think 1.0% is equal to 1 mph. 0.01% is negligable. The S4 wheel is 17 x 7.5 and comes with 225 section tire. Does it handle 235 section OK? anybody fitted this and have experience?
dlubin
9
May 18, 2003 06:20 AM
Ralphie
May 14, 2002 09:39 AM
opusguy1
11
Aug 31, 2001 06:21 AM
Belligerent
May 4, 2001 06:35 PM
Michael Kwok
Wheels & Tires Discussion
Apr 20, 2000 07:12 AM
