Does anybody else's AC suck???
2. Set both temps on full "LO".
3. Set vent selctor to "center only".
4. Turn Recirculation on.
5. Fan at full blast.
6. Apply cold Shiner Bock to your forhead, before drinking. Longnecks fit in the lower cupholder perfectly!
Really - I have found that the Auto controls do not work well in cooling the car.
Honestly, my A/C works great on my 2000 A6. I was just thinking of this yesterday when it cooled my car from over 100 to about 80 in 2 or 3 minutes.
I really think the key is how you direct the air from the vents. It's a big car and if you shoot the air over your head, up the center or some other trick, it'll just cool the back of the car before the front. I think you have to direct the stream so it aims towards you at lieast a little bit. Of course the problem with this is when you get in a 74 degree car and the thermostats are set to 73 degrees, it feels like the car is trying to freeze you out by blowing cold air at you when the rest of the interior is almost the right temp.
Most importantly, it will be a simple fix albeit inconvenient. So schedule an appointment asap and you will be cool hand luke in no time.
Brian
- Tom
