teeny door pocket problem..temp fix...
Old May 5, 2001 | 07:17 PM
miamigrrl [midori]'s Avatar
Default teeny door pocket problem..temp fix...
while I was sitting in traffic yesterday I was looking around the car for something to play with. As I glanced down at the teeny door pocket, I was reminded of some messages posted earlier (<a href="https://forums.audiworld.com/a6/msgs/57618.phtml">https://forums.audiworld.com/a6/msgs/57618.phtml</a>) about not being able to close it. I said to myself, "mine works fine" just as I pressed it open. Lo-and-behold, it wouldn't close! Damn the fates!
When I got home I examined the situation a bit further to find a temp fix: With the driver's door wide open, there's a small metal pin visible on the right side of the small pocket door, as well as 2 grooves which guide the pin. You can use a paper clip to guide the pin as you're slowly closing the small pocket door so it starts following the top groove. then just pull the paper clip out and finish closing the pocket door. It should stay closed. Now just don't ever open it again!
Old May 5, 2001 | 07:41 PM
RRAudi1's Avatar
New Member
Default Re: teeny door pocket problem..temp fix...
Been down the same path, looking for a temporary fix until my next visit to the Service Dept. My house key on the Audi keychain will also work with practice, and is more handy typically.
Seems like an odd design, with no apparent incentive for the pin to follow the correct upper path on closing. However, with practice I've noticed that slamming the door shut seems to work much of the time. I'm speculating that with a slam the pin is more likely to take the right path for some reason, or the pin actually bounces up into the latched position at the end of its travel.
And while it may seem like I have way too much time on my hands to even bother, here in Florida, we have plenty of toll roads, and that pocket comes in pretty handy for quarters...
Old May 5, 2001 | 08:16 PM
Doug2.7's Avatar
25 Year Member
What's a toll road? j/k. WA doesn't have them like the East coast, yet...
Old May 6, 2001 | 06:15 AM
Wowdi's Avatar
Default I saw a new 2.7T at the dealer with the pocket thet wouldn't close....
I just chuckled to myself knowing what I've read here.
Naresh
Jan 12, 2009 05:49 AM
pr0digy30
Jul 16, 2007 01:30 PM
EvanUrS4
Dec 20, 2003 07:10 PM
hrdstrt
Dec 17, 2002 07:26 AM
msquared
Aug 22, 2001 05:49 PM
