Help with Ming Blue!!
Old May 7, 2001 | 03:18 PM
PJH's Avatar
PJH
Default Help with Ming Blue!!
Washed my a6 this morning - it looked beautiful. A couple of hours later I noticed a bird had done its duty on my trunk lid and I proceed to clean it off but I now have this stain from the bird dropping that refuses to come off. How do I remove this?
Old May 7, 2001 | 03:36 PM
phred's Avatar
Senior Member
Default Clay or Imperial Hand Glaze
You need something just slightly abrasive. Bird **** is pretty nasty stuff, as you've discovered. It eats through the clear coat, so always rinse it off right away. And be sure to rewax after getting all remnants off.
Carcareonline.com talks about this fine stuff. You also need to be careful because some birds eat sand to help with their digestion, so when you wipe it off it scratches the paint! Gosh, they're lovely little creatures.
Old May 7, 2001 | 03:38 PM
Ducati Dave's Avatar
New Member
Default Re: Help with Ming Blue!!
Acids from the turd ate the top coat of your paint. I'd suggest Meguirs Fine Cut Cleaner, followed by their swirl remover and then a coat of Hi Tech Yellow Wax or Zymol. Good luck! When I see a droppings I cringe, especially on my Racing Green...might as well be a black car.
Old May 7, 2001 | 07:51 PM
Finman's Avatar
Birds suck---they're dirty, they stink, and their **** eats paint
Old May 8, 2001 | 05:00 AM
Jim Will's Avatar
25 Year Member
Default I had a similar problem last year-->
when my car was new. As Dave said below is the best procedure. A mild cleaning wax will lessen the stain, but don't expect it to go away with 2-3 applications. In my case, I proceeded to polish the car every washing (once per week) within a period of approx 2 months, the stain was completely invisible.
I now have built a nice protective barrier on the paint. Just last Sunday, while in church a bird hit me squarely on the hood. The car sat in the beaming sun for 2 hours until I got out of service. I cringed when I saw the dried bird stain. But, with a spray of quik detailer and a wipe of my microfiber towel, the dropping was gone, with no mark behind.
It may be a good idea to take care of the entire car now, as you have a good reason to. Just use a cleaning polish (the Meguiars Dave mentioned works well) then follow up with a good Carnauba wax (I use Gliptone). You will get a good upper-body workout, but bugs and bird droppings won't be able to harm your finish
Old May 8, 2001 | 01:59 PM
PJH's Avatar
PJH
Default Thanks for the Help
Used the swirl remover and the stain is slowly disappearing. Will need a few more applications. Thanks again for the advice.
Old May 8, 2001 | 04:27 PM
Finman's Avatar
I was no help, just a wise-***. Thanks and praise to phred and Ducati
safelder
Auto Detailing Discussion
Apr 7, 2005 12:14 PM
BaysideRS4
20
Oct 31, 2003 09:26 AM
BkLyNDuDe
Jun 18, 2003 09:20 AM
jgriff
15
Jan 15, 2003 01:10 PM
Jovanotti
Apr 5, 2000 04:36 AM
