Bose speaker specs????
Old Sep 24, 2001 | 10:37 AM
dewdman42's Avatar
Default Bose speaker specs????
Can anyone that knows please fill in the blanks on the Audi A6 4.2 Bose Sound system?
1 - front speakers are 4" or 5 1/4" ?? How easily can 5 1/4" speakers be mounted in the front without cutting the door?
2 - Rear speakers are 5 1/4" or 6 1/2" ?? How easily can 6 1/2inch speakers be mounted in the rear without cutting the door?
3 - The Bose amp has 4 line inputs and it feeds all the speakers in the vehicle. Does this include the subwoofer? No additional amp input for the sub? Can we assume that the Bose amp takes some kind of composite signal from the 4 inputs used for Front/rear and sends the factory sub its signal?
4 - What are the input line level voltage specs on the Bose amp?
Thanks.
Old Sep 24, 2001 | 10:46 AM
2.7tDallas's Avatar
AudiWorld Expert
Default My reasearch shows
The only two choices are
1. Complete replacement of all components including head/amps and speakers.
2. Add a subwoofer.
Bose uses completely proprietary components (has to do with the ohm ratings).
I researched this pretty heavily.
The install shop found a line level output at the connector for the stock sub, and tapped into it there for my amp. The stock sub has a small amp attached, or near it I think. I was not there for the install, but the tech said that there was line level back there somplace.
Please remmeber this is all second hand. If I wanted to pull apart my install to see how they got signal out, I could. But I would prefer not to.
The nice folks at Jensen have "donated" one of thier competition "1 ohm stable" amps and a single 12" sub, which I am going to have install next month into a single 12 enclosure.
Old Sep 24, 2001 | 05:08 PM
Stoney's Avatar
Tech Guru
Default Not quite true...
1. The head unit is identical Bose or non-Bose, and can be "converted" via VAG tool.
2. Thus, you can add amps and speakers while keeping the stock head unit.
3. Precision Car Stereo in Mountain View CA installs a new pre out section to give it a bit more gain and better sound. Not sure if this is necessary for enough gain or not. They've done many, referred by Carlsen Audi.
Old Sep 24, 2001 | 08:12 PM
2.7tDallas's Avatar
AudiWorld Expert
Default Where were you a year ago when I was going all through this??
But thanks for the info.
IMHO the Bose with a sub sounds pretty good. the stock Bose system does a good job all the way from the top down to the middle of the mid. After that it is pathetic. Adding the sub, and making it cross over a little higher than normal seemed to fill in the rest.
It is not a LOUD as I would like, but sounds pretty good, and is a nice option for those who leased
Old Sep 25, 2001 | 09:34 AM
dewdman42's Avatar
Default Re: Not quite true...
Have you ever found out any speaker fitment specs? I am currently trying to decide how much of my system to upgrade as well.
Old Sep 25, 2001 | 09:59 AM
2.7tDallas's Avatar
AudiWorld Expert
Default I have not even tried.
I did talk to the VP of Engineering at Jensen about my girlfriend's car (Prelude) and he said that he is seeing more and more proprietary designs going into front doors. They have nothing for my car, or hers.
He hooked me up with the director of engineering for Crutchfield, the catalog, to see if they had something that they knew would fit the Prelude. He said no, and also said that car companies are making it tougher do.
The only way to do it on the Prelude, was to have a good installer fabricate something.
Old Sep 25, 2001 | 11:00 AM
dzier's Avatar
New Member
Default I added a 15" sub with 500watt amp int he trunk, with line off of facroty trunk speaker....
The difference is great! There is no need to change out the other speakers!!!!!! Set the equalizer settings to your taste! I have a gain adjuster for the sub on the side of the drivers seat by the power seat controls so I can adjust to sound for a song or CD or radio station.
Old Sep 25, 2001 | 11:20 AM
2.7tDallas's Avatar
AudiWorld Expert
pictures please
 Pouria Savadkouei
 Michael S. Palmer
Eric-Paul
Oct 16, 2006 09:34 AM
a4udi98
Jun 29, 2006 02:20 PM
dewdman42
Sep 24, 2001 01:22 AM
Wando
Audi A3 / S3 / RS 3
May 12, 2000 11:29 AM
