Eibach Pro-Kit on the sport 4.2, they are on and work perfectly.
Old Sep 27, 2001 | 07:11 PM
brian 4.2's Avatar
Default Eibach Pro-Kit on the sport 4.2, they are on and work perfectly.
The car corners much flatter. I did my favorite 75 mph corner (23 to 101South) this is a smooth corner with waves in the pament and this car is now a handling fool.Much tighter feel. Regular bumps and holes in the pavement react the same. I do feel it more on the major construction holes.
The front measured 26 1/2 to center of wheel opening now it is 26" .
The rears were 26 1/2 and are now 26 3/4". This would kind of tick me off but the car feels so much better.
I have contacted Eibach in California, they were very helpful and they want to see the car,they will adjust my springs after the SEMA show.
Old Sep 27, 2001 | 07:54 PM
JP4's Avatar
JP4
VERY interesting...thanks for the report brian 4.2!
Old Sep 27, 2001 | 09:30 PM
LMGotts's Avatar
Default Did you feel that the car "wallowed" or had too much yaw movement prior to the Eibach's?
And if so, did the Eibach's address the issue? I have the Audi Sport package and feel like the body roll is flat and controlled - it is actually fantastic in that respect.
Where the car is a real let-down to me is in how the suspension allows the car too much yawing in corners. It almost feels like it's yawing back and forth, right to left, with the body being amazingly flat at the same time. Makes the steering feel weird and wishy washy (technical terms).
What was your motivation in installing the springs? Did you have the Sport package? Did you also have the sway bar(s) installed? What wheel/tires do you have, and what air-pressure do you run?
Many thanks for all of the input. I'd be willing to do the upgrade, but I'm guessing that it's more of a shock-absorber/rebound issue that's making me feel queasy.
Anyone else with suggestions and/or comments?
Old Sep 27, 2001 | 11:17 PM
S1's Avatar
S1
New Member
the kit RAISED the rear by 1/4" ?!? what are the spring rates?
Old Sep 28, 2001 | 04:58 AM
Doug4.2's Avatar
New Member
Great! I need to make the time..aargh!!! Is this a "problem" in the back? Should I wait?
Old Sep 28, 2001 | 06:26 AM
Singletrack's Avatar
Default Re: the kit RAISED the rear by 1/4" ?!? what are the spring rates?
Hey man,
How much did all the s6 mods cost you?
Thanks,
-st
Old Sep 28, 2001 | 06:38 AM
brian 4.2's Avatar
Default (MORE)This is a new sport suspension with 1000 miles on it.
I dont Know the spring rates. When I go to Eibach it will be only for appearance. I really dont have much time on these new springs, hope to do a track event soon.
My motivation for buying the springs was performance. I love track events. Lowered center of gravity and more resistance to roll in the corners. Originally I ordered them for my non-sport suspension car.
When I traded for my new sport susp.car I was amazed at the difference in handling between the 2.(and I had installed the thicker swaybar). This takes it one more level without sacrificing that great ride quality I enjoyed with my 1st Audi.Apperance is secondary but of course I want bothe ends of the car close to the same height.
I'm sure Eibach will sort this out, as they are very interested in thier techs seeing the car.I think a little patience on my part will go far to getting the rear springs( and future springs) correct for our cars.
I hope to make that get together in Nov. then you can test it for yourself.
Old Sep 28, 2001 | 09:06 AM
big whup 4.2's Avatar
New Member
harumph!
 Pouria Savadkouei
 Michael S. Palmer
boostbuddy
Mar 7, 2009 11:43 AM
LRDOFTHERNGS
10
Jun 14, 2007 09:21 AM
coc
May 12, 2004 12:52 PM
audiboy_17
Apr 3, 2002 08:00 PM
grishfish
11
Jul 26, 2000 07:26 AM
