what should tire pressure be on a 2.8
Old Sep 29, 2001 | 07:46 AM
dittozip's Avatar
New Member
Old Sep 29, 2001 | 08:23 AM
2.7t john's Avatar
New Member
take a peek inside rear passenger door for factory recommendation, not what is on sidewall of tire.
Old Sep 29, 2001 | 10:07 AM
DWP's Avatar
DWP
I run 35 all round. Hot dogs run a little higher.
Old Sep 29, 2001 | 10:22 AM
Muhammad's Avatar
I think spec is 36... 34-38 would be good IMO.
Old Sep 29, 2001 | 10:44 AM
CleanAudi's Avatar
The fuel door says 33 on all tires, how are you guys putting in 35? isnt that dangerous
Old Sep 29, 2001 | 10:58 AM
Finman's Avatar
Default The rec on the car is the mfg's rec for a comfy ride, balanced between handling, economy, and...
comfort. The Max on the sidewall of the tire is the max pressure that the tire can safely handle. You can choose whatever you want, but there may be changes in grip, ride, noise, handling, etc.
I wouldn't underinflate them, however...ala Ford Exploders...although I think you'd be a lot safer if your tire delaminated than if you were in an Exploder.
Old Sep 29, 2001 | 05:03 PM
ApertureA6's Avatar
New Member
Been using 34 on the original Contis and now on the Michelin Pilots. Feels good.
jclaib7
Audi A3 / S3 / RS 3 MKII
33
Jun 17, 2016 12:30 PM
wiseguy67
A7
15
Jul 1, 2015 09:49 AM
tictaq
A4 (B7 Platform) Discussion
Aug 1, 2006 02:26 PM
A4Grover
Oct 20, 2005 05:01 AM
Mike
Wheels & Tires Discussion
Jul 17, 1999 12:08 AM
