I changed the oil and filter in my A6 and now...
Old Jan 5, 2002 | 11:22 AM
A6StylingMasterpiece's Avatar
New Member
Default I changed the oil and filter in my A6 and now...
The ABS and Brake warning lights are coming on and the car won't start. Doesn't crank, or anything. I can't think of anything I did even close to the brake system. Anybody know what's going on?
Perplexed and dumbfounded.
Old Jan 5, 2002 | 12:07 PM
FlyBry2.7T's Avatar
New Member
Default Re: You got me! I've changed my own oil and I did not notice any way to render the car useless...
You might be better off calling roadside assistance, have them come get the car and take it in as "it simply will not start". Good Luck and let us know the result.
Old Jan 5, 2002 | 12:13 PM
Asixer's Avatar
Default Re: I changed the oil and filter in my A6 and now...
Have you checked the battery yet? They can completely die at anytime. Turn your headlights
on, with the ignition in the on-position of course, and measure the voltage across the battery
with a voltmeter or DMM. Is it normal or low?
If it is low, say 7-8 volts, it is a dead battery.
If it is the battery, after replacing it check the charging system.
Old Jan 5, 2002 | 01:00 PM
Seattle Scott's Avatar
Break a cable near the brakes when playing w/ the lower engine shield? Brake fluid on the ground?
Old Jan 6, 2002 | 10:22 AM
New Member
You were right! The battery was dead. It was reading less than 5 volts with the lights on. I charged up the battery and it started right up, no problems. I realize now that I had left the ignition in the "on" position for about 20 minutes and this ran down the battery.
Thanks!
vandexa3
Audi A3 / S3 / RS 3
Nov 17, 2024 06:53 AM
quattrotto
15
Aug 13, 2024 10:35 AM
Nightlifephantom
11
Sep 30, 2018 06:40 PM
SpecialBuild87
Jul 16, 2008 05:03 PM
anolin
Apr 10, 2008 10:57 AM
