rear brakes
Old Jan 5, 2002 | 04:35 PM
98JakeQuattro's Avatar
New Member
Default rear brakes
how do you push the caliper back on a 98 A6 Quattro???
Old Jan 5, 2002 | 05:33 PM
DWP's Avatar
DWP
Default It's tricky
Here's a description of one man's method on an A4 (which is almost identical to my 99 A6), or you can get a special tool but I'm not sure where.<ul><li><a href="https://www.audiworld.com/tech/wheel.html">https://www.audiworld.com/tech/wheel.html</a</li></ul>
Old Jan 5, 2002 | 05:50 PM
ryoung's Avatar
Elder Member
Default The special tool ...
... that allows you to screw the piston back in.
I haven't tried this specific tool, but I saw it recommended in the A4 forum.<ul><li><a href="http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40732">HarborFreight brake tool</a></li></ul>
Old Jan 5, 2002 | 05:53 PM
Seattle Scott's Avatar
Default You screw it back in. Get a special tool at the local auto store. It will be a cube with six
sets of "****" on it for different cars. The cube has 3/8" ratchet squares in it. I think they are 3/8", maybe 1/2". There will be one side with 4 **** in a square. The tool costs about $6?? Grind off two diagonally oppossed ****...
Before
After
Sometimes it helps to screw the pistion out a litle and then start screwing it in. Remember to apply some pressure when screwing in the cylinder too. The **** fit in the two slots shown in the piston below.
<img src="http://pictureposter.audiworld.com/12414/brakerearpassenger1.jpg">
Old Jan 5, 2002 | 05:59 PM
Default Here, I stole Andrew's (IqDOU?) picture of his tool with ground off ****.
By the way, the official Audi tool costs...about $60 as I recall. The Audi tool looks nice.
<img src="http://pictureposter.audiworld.com/1889/braketool.jpg">
Old Jan 5, 2002 | 06:10 PM
Default Nice looking. I'd like to see it. Screwing in those pistons is not easy. That T bar could either be
bigger or there is some mechanical advantage I'm not seeing.
A good tool would be nice. With two people (one to hold the brake assembly and cube tool, another to run the ratchet with both hands, it wasn't too bad. Alone it would be a PIA.
Old Jan 5, 2002 | 06:15 PM
Gerry's Avatar
Default Some of them even come set up with two pins
<center><img src="http://pictureposter.audiworld.com/2251/mvc-002f.1.jpg"></center><p>
No grinding required. This was from Autozone and fits on a 3/8" extension.
Old Jan 5, 2002 | 07:17 PM
QCRAZY's Avatar
The tool in the picture that Scott posted is from Napa. Fits on a 3/8" ratchet!!
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 5, 2002 | 08:57 PM
brian 4.2's Avatar
Default Duh... I drove past "Harbor Frieght" to pick up the $150 "Schlay Tool" at a tool specialty shop.
Didnt think to stop in for this.
Old Jan 5, 2002 | 09:03 PM
ryoung's Avatar
Elder Member
Your picture and illustration -- worth 2000 words!
